i have searched and searched and searched
does anyone know where to find step by step instructions to wire my obd1 plugs to my obd0 harness. i know its easier to buy a harness from rywire or boomslang, but i dont wanna spend the money.
tia
tia
step1-you depin the obd1 plug.step2you depin the obd0 plug.(these steps can be reversed)step3you put the obd0 wires in the obd1plug-in the correct pin location obviously.ok.your next question is,how do i remove the pins.look inside the plug.the male ends will be facing you.they have a little plastic clip holding them in place.lift it up with a very small flathead or needle.pull hard.pin is out.repeat.
crx_si-r
Feb 26, 2010 07:48 AM
