93 civic dohc vtec swap. OK to Use the DX Harness???
Old Aug 12, 2002 | 04:15 AM
allmotor.net's Avatar
Default 93 civic dohc vtec swap. OK to Use the DX Harness???
puttting in a dohc vtec motor and was wondering if its ok to use the stock dx harness? do i have to add/remove wires to make it work. any feedback appreciated.
Old Aug 12, 2002 | 04:25 AM
eg6ajk's Avatar
Default Re: 93 civic dohc vtec swap. OK to Use the DX Harness??? (allmotor.net)
of course, less hassles then using JDM harness (as it doesn't work)
for dohc vtec swap its only 4-6 wires at most to be added which is very easy
Old Aug 12, 2002 | 01:10 PM
Evil DOHC's Avatar
Default Re: 93 civic dohc vtec swap. OK to Use the DX Harness??? (eg6ajk)
Yes, only a couple wires to add, no biggie. If you are good with wire loom, it will look like stock.
EVIL
Old Aug 12, 2002 | 11:52 PM
ndogg's Avatar
ya, just like the others said plus i think there are a few wires that need to be lengthened. also, this willl only work if the new motor is an OBD1 engine. if it's not, then you will need to get the connectors for alternator, injectors, and distributer off of an ODB1 engine and put those on there.
jdmeg6honda
Aug 13, 2011 04:00 PM
michaelsej1
Aug 27, 2010 06:43 AM
hmtcrxsir
Jan 17, 2010 03:19 AM
streetracerof06
Nov 9, 2005 02:30 PM
98civicEX
Jul 29, 2002 04:01 PM
