A/C bracket/ compressor ?
I did a little bit of searching and could not come up with the answer I want so here it is....
I am swapping my ls in my 98 ek this weekend and I was wondering if I can use the ls a/c bracket+mount. I plan on using the ls compressor and changing the a/c lines to the teggy lines. I already fitted the lines and I just wanted to know if there is going to be fitment issues with the ls compressor? They dont look much different in size when compared to each other. What do you guys think?
Also with the Power steering...the CRV bracket works with the D series pump right? Just need some of these small questions answered. Thanks for your input
If you use the LS compressor you can but your line wont line up properly you have to twist one of them a lot to make it fit or if you are keeping the Civic compressor with you should you need to get the AC bracket from a 93-97 Del Sol vtec (not the Si model because it has a single cam) cost about 110 at the dealer but makes evrything fit with no complications.
yea well i would have bought that bracket but I already paid for a bracket on here and didnt recieve it(i paid for an empty box). I found an a/c line that fits to where I wont have to twist it at all(the line from the condenser to compressor).
As long as the compressor fits in the bay and has no issues then thats great!
ClassyG
Dec 28, 2013 09:01 AM
averyvm
May 27, 2008 10:10 AM
SrT4u2nV
Aug 28, 2006 03:53 PM
