over sized piston rings
Old Mar 8, 2009 | 01:29 PM
NubImports's Avatar
Default over sized piston rings
i bought a car that was resontly rebuild and they used oversizd piston rings theres about 400 miles on the engine and i was wonder my car over heats like if i go easy on it it wont over heat but if i go fast like not over 50 it will start to over heat...what can be the cause??
im pretty sure im getting curculation the hose at the bottom heats up wayyyyy slower then tha hose ont he tiop of the radiator and yes my radiator fan comes on as soon as i turn my key to the ready to start position idk what its call but a click before u start it..im not sure if the water pump was replaced or not i know its a D15B7 with a Y8 head
very high compression from what ive been hearing i need sugestions and help it over heats runs fine but i just cant find why its ****ing over heating
Old Mar 8, 2009 | 05:52 PM
FlatBlkEk's Avatar
Default Re: over sized piston rings
was the waterpump replaced are you getting circulation? does your fan work?
Old Mar 8, 2009 | 06:03 PM
NubImports's Avatar
Old Mar 8, 2009 | 07:01 PM
Rheg6's Avatar
check your thermostat yet ?? and when u change it bleed it right too or else u be air bound and still overheat
Old Mar 8, 2009 | 07:59 PM
NubImports's Avatar
yes i have check the thermostat i boght the car off craiglist about a week ago and it doesnt seem to be a blwon head gasket or anything idk like i wentt to replace the thermostat and there wasnt even one in and like when i got tha car i blew a bypasss hose and like looked int ha trunk and there were like 2 other blown bypasss hoses...it seems like im getting good circulation threw my block but its still overheeating...ummmm how do i know when my cars coooling system is fully bleed liek mine bubled for awhillleee and neevr like stopped with small bubbles so idk it confuses me i rally need some helpim 17 tryna get this car running so i can get a better job so if anyone knows anythigndrop me a line and let me know whats up
AlfieRoach
17
Jan 17, 2010 08:25 PM
jeremyrocksursox
Jul 14, 2009 11:53 PM
Jesse1920
Jul 5, 2008 11:51 AM
ACR
Acura TL, RL & ZDX
Dec 9, 2003 03:44 PM
kreeme
Dec 9, 2002 05:59 AM
