Car Problem
Old Mar 7, 2009 | 09:04 PM
kc_boss_816's Avatar
Icon3 Car Problem
1994 Honda Civic Dx D15B7 Motor
this is the code its throwing.(took this video today)
http://www.youtube.com/watch?v=bmhilc3lpZg
what would cause the motor too idle kinda high???? also when i hit the gas its a slight pause then it kinds sputters/jerks when taking off????
i do smell gas and black smoke comes out the muffler when you rev it???
first my car wouldn't start yesterday and i was told it could be the main relay. i replaced that it starts up but now it has these other problems.
anyone have any ideas on were i should start???
iam doing a tune-up and replacing the fuel filter
iam really confused so any help but be appreciated.........
Old Mar 7, 2009 | 09:20 PM
Former User's Avatar
Default Re: Car Problem
CEL code 6 = coolant temperature sensor
This is the two-wire sensor located immediately below the distributor. The symptoms are consistent with this sensor being bad.
Old Mar 7, 2009 | 09:25 PM
so just buy a brand new sensor and that should fix my problem?
Old Mar 7, 2009 | 09:48 PM
Run the engine until it is fully warmed up. Turn the engine OFF, disconnect the 2P connector from the sensor, and use a multimeter to measure the resistance across the 2 terminals of the sensor. If the reading is not in the range of 200-400 Ohms, then replace the sensor.
Old Mar 7, 2009 | 10:04 PM
ok.....i will try that tomorrow
thanks
Old Mar 7, 2009 | 10:31 PM
were exactly is the water temperature sensor located?
iam looking online trying to find some pictures to show me the location of the sensor but i cant find any.
Old Mar 7, 2009 | 11:21 PM
trustdestruction's Avatar
pretty sure it's on the thermostat housing
Old Mar 7, 2009 | 11:23 PM
i will check in the morning and see if i can find it.
would you happen to know what color wires does the plug that goes into the sensor have?
Old Mar 7, 2009 | 11:27 PM
sorry, it's by the distributor, i was mistaken
Old Mar 7, 2009 | 11:29 PM
Old Mar 7, 2009 | 11:46 PM
thanks man
Old Mar 8, 2009 | 08:00 PM
i have another question.
would the change in temperature make the car act up? because today its way colder than the past previous day when my car first started to mess up. i had no problem with the car starting or idling nor a check engine light???
Old Mar 8, 2009 | 08:31 PM
It probably just means the problem is intermittent. The issue will likely soon return, so troubleshoot and fix as soon as possible.
Old Mar 8, 2009 | 08:34 PM
that's what i figured. i plan on trouble shooting and fixing my problem tomorrow.
since it will be warming up here soon. cant afford to be stuck anywhere
thanks for your help bro.
semibull
Apr 14, 2014 04:51 PM
KC GSR
Aug 22, 2008 11:17 PM
93CivicSiSOHC
21
Feb 4, 2005 04:10 AM
HONDABOND
Oct 12, 2003 08:03 PM
wickedxboi
Jul 28, 2002 08:34 AM
