Can I check for a bad ECT sensor by unplugging it?
My car is very hard to start when the engine is cold. Once it starts, I can immediately kill it and it will start right up perfectly. Runs perfect as well.
I suspect that it is flooding due to a bad ECT sensor. Can I just unplug it to see if that is the problem without having to use a multimeter?
Re: Can I check for a bad ECT sensor by unplugging it? (KC GSR)
If you have a Civic with a Fast Idle Valve, you might want to try cleaning it.
Otherwise, I think you should measure the fuel pressure and troubleshoot the distributor.
Re: Can I check for a bad ECT sensor by unplugging it? (RonJ@HT)
may i know where is the water temp sensor (ECT) locate? i got error no. 6..bad ECT
thannon2
01-15-2009 11:37 AM
