jdm headlight install
Old Mar 7, 2009 | 04:42 PM
creepass's Avatar
Default jdm headlight install
ok the other day i got the headlights and i tried to install them to see how they fit, and i took the usdm headlight off the bracket and i was going to put the ef9 headlight on and it dident fit. i have a 89 civic im not sure if i need a 90-91 bracket. or is there a different way?
Old Mar 7, 2009 | 04:45 PM
Turbo Dan's Avatar
Default Re: jdm headlight install
remove everything that is attached to the factory headlight, the jdm needs NO bracket at all, it bolts straight to the front end.
im guessing you still have the skeleton for the usdm headlight bolted in, just remove it!
your front end should look like this when you are doing the install
notice the lack of headlight brackets
its a crx but same idea for civic
Old Mar 7, 2009 | 05:02 PM
creepass's Avatar
no i took it off, i actually hooked it up right then it just dident seem right i thought you needed a bracket, i just dont have my filler or hood yet, its still being shipped, but cool thanks alot.
Old Mar 7, 2009 | 08:14 PM
Turbo Dan's Avatar
oh, i thought by not fit right you meant it didnt bolt up properly.
i didnt know you meant it was because of something so obvious
Old Mar 7, 2009 | 08:30 PM
creepass's Avatar
ahh they did, i just never had the sir front end before, and i never new how the hooked up, no one that lives by me has one but one guy that i know of, but thanks for your help.
Old Mar 7, 2009 | 11:50 PM
~sp33~'s Avatar
EFB055
So it does fit, but fitment is bad?
Old Mar 8, 2009 | 11:35 AM
creepass's Avatar
no its just my sir hood and bumper filler are still being shipped still, thats why it looked weird. but i thought that you still needed the brackets,
Old Mar 9, 2009 | 08:21 PM
creepass's Avatar
well since they are only one bulb how do you do install them, since my stock headlight has 2 bulbs, i have eg bulbs and wiring if that will work.
Old Mar 9, 2009 | 11:54 PM
Ldo's Avatar
Ldo
Assuming you already have bulbs and sockets for your jdm headlights: cut up your stock headlight wiring at the sockets and solder them to your jdm ones. Connect all black ground wires together. 2 wires left, one is for high beam, one is for low beam. I forgot which color is which, just hook them up and test them out, rewire them if need be.
BTW, check out the FAQ section, there's a writeup for jdm sir front end conversion. Everything is there.
Old Mar 10, 2009 | 09:41 AM
creepass's Avatar
ok i will thanks alot
Old Mar 10, 2009 | 01:59 PM
creepass's Avatar
i got it.
Rttix1337
Jun 18, 2014 05:42 PM
XhaloZ
Oct 16, 2009 01:52 PM
GSRBrent
Lighting
Nov 21, 2007 07:10 AM
Vincent.
Jul 10, 2004 01:58 PM
jdm_cars
Nov 18, 2003 04:38 AM
