projector headlight bracket??
my projectors are missing the bracket i presume that holds them in place were you want them, they look straight down and i cant see a thing, can i buy somthing to fix them or jimmy rig with clamp, pm with further info
how are they missing a bracket?
there are adjustment screws on the back of the unit.. use a phillips head screwdriver, and turn the screws...
The blue line is at the same level as the headlights... on the wall.. make sure you are on a flat surface...
When u aim the against a wall follow this guide:
thx to B20inDCinLBC who posted it first, and thx to wickedcarparts for hosting it.
That diagram isn't totally correct.
The left side of the cutoff pattern should be about 2 1/4" below the height to the center of the headlight when you're 25 feet from a wall. That diagram shows the left side of the cutoff at the same height as the center of the headlight.
Rttix1337
Jun 18, 2014 05:42 PM
