CRX wheel alignment?
Old Mar 7, 2009 | 04:46 AM
Lanolin18's Avatar
Default CRX wheel alignment?
Last friday it was raining pretty hard here and i jumped over a curb with the driver side rear tire. i blew the side wall out of the tire so i go home and put my steelies back on the next morning.. well no problems there. but the tire does not sit level now the bottom of the tire sits further out then the top of the tire.. what could be goin??
Old Mar 7, 2009 | 05:08 AM
~sp33~'s Avatar
EFB055
Default Re: CRX wheel alignment?
You could've bent a control arm, trailing arm, sway bar... Have a look and see what's bent.
Old Mar 7, 2009 | 05:34 AM
kojack_0's Avatar
take a picture and show us and we'll tell you the problem.
that helps most of the time.
it seems that you could have bent something around the area where the arrow is. [sorry dont know what thats called]
if it was the lower control arm thats bent the bottom part of the wheel would be inwards rather than the top.
you should check your trailing arm bushings also, which is where the triangle is if you didnt know what it looked like.
Homesickelian
Mar 5, 2007 04:06 AM
Baron55
Mar 12, 2006 05:00 AM
hapexamendios 2.0
22
Dec 27, 2005 03:32 AM
lilman36
Nov 24, 2003 07:49 AM
badnan
May 29, 2002 12:21 PM
