Question about 4x100 centerbore
Old Mar 6, 2009 | 02:36 PM
Si Trav's Avatar
Default Question about 4x100 centerbore
While shopping for rims which I do pretty often I always question tons of wheels that most Honda guys woulden't run. It is to my understanding that not at 4x100 wheels regardless of offset will fit a Civic due to the center bore being different.For some reason the number 57.1mm comes to mind but I could be very wrong.
Cliffnotes: What is the standard bore for a 4x100 wheel on a Honda Civic, being specific my 1991 Si and my 2000 Si
Thanks in advance...im sure someone knows the answer to this question.
Old Mar 6, 2009 | 03:10 PM
It Wasn't Me's Avatar
Default Re: Question about 4x100 centerbore
56.1mm
Old Mar 6, 2009 | 03:11 PM
toyomatt84's Avatar
Sanji
Both of your cars have a hub bore of 56.1mm.
Old Mar 6, 2009 | 03:50 PM
Si Trav's Avatar
thanks for the replies guys.
Old Mar 6, 2009 | 03:59 PM
nsxtasy's Avatar
H-T Order of Merit
These charts showing center bores are about 99 percent accurate (exceptions - they don't break out the ITR or show the different center bores front vs rear for the NSX or S2000):
Honda bolt patterns and center bores
Acura bolt patterns and center bores
Old Mar 6, 2009 | 05:02 PM
r.wright's Avatar
you were thinking about volkswagon center bore. european cars need either hubcentric wheels or hub rings due to their stud bolt design opposed to the conventional lug nut design of all asian cars and american cars.
that is the reason it is more rare to find an aftermarket wheel that comes in 56.1(honda 4x100 or 54.1mm(toyota/scion 4x100)
Old Mar 6, 2009 | 06:17 PM
Si Trav's Avatar
thank you very much, awesome reply.
Old Mar 6, 2009 | 11:51 PM
Si Trav's Avatar
thanks for the knowledge!
Old Mar 24, 2009 | 12:19 AM
blinx9900's Avatar
With that said does the ITR have a different bore size?
Old Mar 24, 2009 | 09:03 AM
r.wright's Avatar
it's 64.1mm
Old Mar 24, 2009 | 06:09 PM
blinx9900's Avatar
it's 64.1mm
Thank you!! Is that the same as the CTR hubs?
Old Mar 24, 2009 | 07:03 PM
r.wright's Avatar
as for their wheel center bore-YES
travbrack
Dec 20, 2010 01:08 PM
travbrack
Dec 20, 2010 11:11 AM
Chuckles99SH
Jun 27, 2007 12:17 PM
mikeunreal
Dec 1, 2005 05:43 PM
