Radiator fan won't turn on
Old Mar 6, 2009 | 12:33 PM
user 93082343's Avatar
Default Radiator fan won't turn on
My radiator fan won't turn on, ever. I don't know why. What are some simple things I can look at to trouble shoot, or somethings I can tell you guys to help me out.
Also to help me test whether or not it works in this process when idling and not moving, when should it normally turn on? after a few mins?
-John
Old Mar 6, 2009 | 12:35 PM
Paul-R's Avatar
Default Re: Radiator fan won't turn on
Replace the fan switch .
Old Mar 6, 2009 | 12:43 PM
crxjarred's Avatar
um when i got myn it didnt work and i had to swap some plugs and stuff and i waited like a hr or so for myn to come on so mabe u didnt wait long enuff
Old Mar 6, 2009 | 01:11 PM
Where is the fan switch and how do I know if it is bad?
-John
Old Mar 10, 2009 | 08:13 PM
reznunt's Avatar
-John
it's on the back of the block near the oil filter and it can be tested as follows:
also check your fan fuse and relay. you can also hardwire the fan to the battery to test the fan itself. i did that first.
Old Mar 10, 2009 | 08:45 PM
Woot! Thanks for that! I will try it this weekend.
-John
Old Apr 2, 2009 | 11:35 AM
I tested the fan, it works.
I tryed to test the relay, but.... it doesnt seem to be working. As with any other relay I should hear it click when I energize the coil right?
-John
Old Apr 2, 2009 | 11:46 AM
jb2wheels's Avatar
You should hear/feel a click.
Did you do the test(s) outlined above?
How did you test the fan?
My AC fan relay was dead when I got the car. I grabbed a handful of relays at the junkyard for $5. Now I have spares.
Old Apr 2, 2009 | 12:00 PM
Why would it matter how I tested the fan as long as it spun? As long as the fan spins....the fan is good.
I did not do the tested outlines above, because I only tested the relay, and I only did the relay tests.
-John
Old Apr 2, 2009 | 12:06 PM
shaggyeg6si's Avatar
Easy check, worked for me, check the fuses.
Old Apr 2, 2009 | 12:17 PM
90civichbsi's Avatar
test the fan switch by unplugging the signal wire ( i think its yellow/green, the other is the ground and is black so not that one) then connect it to a ground. If the fan works its your fan switch not the relay.
this is alot easier than taking the thing all the way out and sticking it in boiling water or testing the relay as the manual states
Old Apr 2, 2009 | 12:19 PM
Will try this tonight, I already checked the fuses. Nothing blown.
-John
Old Apr 4, 2009 | 07:38 AM
BIG T's Avatar
does the ac relay matter in the operation of the fan
Old Apr 4, 2009 | 08:50 AM
Crx Jimmy's Avatar
make sure the car is on when you do the test. never underestimate the dumbasses on h-t.
fatl13ert
Oct 22, 2012 12:41 AM
Nino_eg6
Jan 28, 2009 02:28 PM
limit
Dec 30, 2008 01:28 PM
loup05
Oct 22, 2006 05:20 PM
