Alum Piping in Schedule 40 ?
Old Mar 6, 2009 | 09:20 AM
ExVtec's Avatar
Default Alum Piping in Schedule 40 ?
I was looking to order some straight 2.5" alum pipe.
What I have currently is 16ga.
Everything I see says schedule 40? Is that the same, if not whats teh difference?
Thanks
Old Mar 6, 2009 | 09:27 AM
ToxicFabrication's Avatar
OG Fabricator
Default Re: Alum Piping in Schedule 40 ?
wow, the 16g is .065 and the Sch40 is .145. the Sch40 is ALOT thicker
Old Mar 6, 2009 | 09:30 AM
ExVtec's Avatar
Well I know alot of people making manifolds use schedule 10/40/etc. I figured it was alot thicker, but I didn't know by how much.
Thanks.
Old Mar 6, 2009 | 09:33 AM
AceRaceParts's Avatar
Well, you're trying to compare tube (16ga) to pipe (s/40)... and they are two totally different things.
Tube - Size is based on the OD (outside diameter)
Pipe - Size is based on a theoretical ID (inside diameter).
If you are looking to stick with the 2" OD material then tube is what you're looking for. When you call or look online you need to specify that you are looking for 2" tube and then give them the wall thickness you are looking for (in this case, 16 ga). Calling out pipe is the same and the appropriate sizes and terminology need to be used to ensure that you get the correct material.
The short of it... No, the 16ga and s/40 items are not the same and cannot be compared.
EDIT: The biggest problem I see is fabricators, end users, and even other distributors using incorrect terminology like "piping" to describe tube. Pipe or "piping" should only be used to refer to pipe sized material. "Intercooler piping" should be called tubing because of the material used to make it.
Old Mar 6, 2009 | 09:39 AM
Captain Bondo's Avatar
Wait- so you're trying to make a header from aluminum?
Failboat?
Old Mar 6, 2009 | 10:03 AM
ExVtec's Avatar
Failboat?
**facesmack**
No, i/c piping, I was just using the comparison I've seen in making manifolds with sch 40 stuff.
Thanks for the help all, I was unaware in the difference between piping & tubing.
non-VTEC
Welding / Fabrication
19
Apr 23, 2012 12:17 AM
JdmEKCivic
Dec 15, 2005 07:51 PM
Sprockets
Aug 2, 2004 11:39 PM
5thgen
Feb 25, 2004 09:15 PM
