Passing smog in CA with an ITR engine...
Old Aug 11, 2002 | 08:13 PM
comptechgsr's Avatar
Default passing smog in CA with a jdm itr engine...
might wanna swap this into my egg....
anyone pass smog wit it?
thankz in advance
Old Aug 11, 2002 | 08:15 PM
csufweed's Avatar
Default Re: passing smog in CA with a jdm itr engine... (comptechgsr)
well a JDM CTR was able to be registered in CA... so who knows!
Old Aug 11, 2002 | 08:16 PM
AllMotorITR's Avatar
New User
Default Re: passing smog in CA with a jdm itr engine... (csufweed)
I'm sure it can pass smog, but not state referee.
Old Aug 11, 2002 | 08:23 PM
Default Re: passing smog in CA with a jdm itr engine... (1 FAST R)
pass smog but not state referee?
state referee is pretty much a designated smog check area...
the reason why cops give u a state ref ticket, is b/c of the corrupt shops that u can pay to pass smog....
i wanna pass smog legally.
anywhere in CA (state ref, or ur basic shell station wit smog check machinez
Old Aug 11, 2002 | 08:27 PM
csufweed's Avatar
im pretty sure it will pass smog... but visual inspection it wouldnt pass.
Old Aug 11, 2002 | 11:30 PM
Louie's Avatar
What would Chente do?
Default Re: passing smog in CA with a jdm itr engine... (VTEC CX)
hard to say.....assuming the smog tech is engine code savy, most likely you'll fail the visual inspection part of it.
As far as tailpipe emissions go, the j-spec engine will have higher compression. Never smogged one myself so i don't know what effect the bump in comp. will have on NOx levels. Remember we only have 91 octane(socal) so if you running the j-spec ecu (designed to run on higher octane) you might be compounding the problem. Not sure if i helped..sorry.
Old Aug 12, 2002 | 01:02 AM
OutLaw MR's Avatar
You'd need to take it to your local referee station for inspection and then they'll tell you how to comply.
Old Aug 12, 2002 | 01:15 AM
batibot's Avatar
man that's alot of BS..CA. got a lot of nonsense laws man
Old Mar 7, 2004 | 09:06 PM
lvbuckeye's Avatar
Default Re: passing smog in CA with a jdm itr engine... (batibot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batibot &raquo;</TD></TR><TR><TD CLASS="quote">man that's alot of BS..CA. got a lot of nonsense laws man </TD></TR></TABLE>exactly. and it's bullshit. Why TF can you just go and register some shitty, leaded fuel drinking, smoke spewing, gas guzzler 63 Impala no problem, but you have to get the Late model cars smog checked? it just makes NO SENSE! the New cars aren't the ones creating the smog! it's that friggin' old ***, oil burning POS that doesn't even need to get checked!
Cali Emissions =
Nevada Emissions =
gotta do it gangsta style here...
-edit-
i just realized that i bumped a thread that has been dead for a year and a half... sorry. i didn't mean to.
boxeocampeon
Engine Management and Tuning
Aug 24, 2009 03:13 PM
PePpeRedDc5
May 4, 2005 08:01 PM
Nfurno
Jan 20, 2004 03:34 PM
