Alternator.
Old Mar 5, 2009 | 06:24 PM
Cole89ef's Avatar
Default Alternator.
Would the alternator not being plugged in cause the the engine to start and not stay running.
Like just run for a second and cut off.
Old Mar 5, 2009 | 07:38 PM
Cole89ef's Avatar
Default Re: Alternator.
Bump
Old Mar 6, 2009 | 03:25 AM
redflaredcrx90's Avatar
yes and no.the battery is used to help start the car and the alternator keeps the current flowing . . so if your alt isnt working or working right the car will run off the bat.. so at some point that battery wont be able to keep that car running shut off. check you fuel plugs and make sure you dont have any vac leaks.
Old Mar 6, 2009 | 03:40 AM
ef yu's Avatar
sounds like you have a different problem.
if the battery was weak, it wouldn't start the car.
now if the car did start, and dies seconds later, you shouldn't be able to start because (assuming) the car ran off the battery.
eazy64
15
Nov 11, 2010 08:53 PM
asc
Jun 20, 2010 08:15 AM
tigueremalo
Jan 22, 2007 03:10 PM
AznInvasion
Nov 27, 2004 07:03 PM
EJK
Feb 4, 2003 08:03 PM
