Rear Doors
Old Mar 5, 2009 | 04:37 PM
jdmed3's Avatar
Default Rear Doors
I'm rewiring my stereo and running speaker wire to the back and am/sub wire'n and had my doors open i closed them and now they wont open wether i pull the outside or inside handle unlock/lock wont come open either side of the back but the front 2 are fine... any ideas?
Old Mar 5, 2009 | 05:46 PM
jdmed3's Avatar
Default Re: Rear Doors
bump
would like to have my 4 door a 4 door for a couple more months
Old Mar 5, 2009 | 08:37 PM
jdmed3's Avatar
Need some help please
Old Mar 5, 2009 | 08:45 PM
jhammond_82's Avatar
Reject Papi
welll. my brother just ran into this problem with a mazda mpv he just bought. the bar inside the door that controlls the locking mechanism is broken. he had to take the door and panel off with it closed. it is possible, but it is a pain in the ***. the striker will hold you back some. if you got small arms, you can get in between the door, and panel and slid the bar by hand.
Old Mar 5, 2009 | 08:48 PM
~sp33~'s Avatar
EFB055
You can try taking the door panel off enough so that you can reach the lock mechanism.
Old Mar 5, 2009 | 09:18 PM
ef jay's Avatar
I ran into a problem with a parts car I stripped. The mechanism can get stuck when the handle is pulled and the door lock is engaged. Once the the mechanism is stuck in the open position, of course the door won't open due to the lock, the lock can not be disengaged. The mechanism must be returned to it's normal position to allow the release of the door locks. The door panel can be removed with the door closed but a tab may be damaged because you won't be able to remove the screw towards the rear of the door panel. I hope this made sense.
Old Mar 5, 2009 | 09:43 PM
jdmed3's Avatar
well i know how to fix the problem the only thing is that the doors are closed so i cant get the door panels off
Old Mar 6, 2009 | 02:24 AM
ef jay's Avatar
The door panels will come off with out any damage to the panels. You can remove all but one screw from the panel. You just leave that one screw in, towards the back, and pull the panel out. You might damage a small plastic tab not the panel. You will have to replace the tab. At this point it's your only option. I may have some spare tabs. The front doors use the same tab. I'll check. Start at the bottom corner, towards the front. Just take your time it will come off.
Old Mar 7, 2009 | 06:27 AM
jdmed3's Avatar
ok i pulled the car in and i'll try gettin the panels off its just givin me more motive to do my coupe conversion earlier
They worked fine except the driver side had to be opened from the inside only and now they both wont open i might have put that child lock on but it doesnt explain why the outside wont work... i'll post pics after i get the panels off
cant even get the panels off i got the 2 screws out and cant even move the panel cuz it overlaps the doorjam where those plastic pins are that hold it on...
im really about to just unbolt the doors to get em off
Old Mar 7, 2009 | 07:54 AM
Reject Papi
not a bad idea taking the door off. if thats the only way to get it fixed...
Old Mar 7, 2009 | 08:02 AM
jdmed3's Avatar
sounds like my only option i just dont get how they go from working to i close them and they dont open
Old Mar 7, 2009 | 08:30 AM
nfereorhatch's Avatar
The rear passenger door on my sedan does that sometimes, oddly enough i have no idea why and if i leave it alone it usually "fixes itself" and it will open. Perplexing..............
Old Mar 7, 2009 | 08:39 AM
jdmed3's Avatar
ya the rear doors arnt at the top of my list of things to fix its whoever has to ride in the back's problem and as is there climbin in like its a coupe lol
Old Mar 7, 2009 | 10:16 AM
ChrisHinds's Avatar
my sedans doin the EXACT same thing! one day ill go out there and it will open fine... then the next day it wont open at all from either side.. its pissing me off i dont get it?....also the window on that door wont roll down bad wiring maybe? any ideas?
Old Mar 7, 2009 | 10:25 AM
jdmed3's Avatar
do you have power windows? mine are manual thankfully but if its goin down slowly or not at all then take the window motor out and clean it up if its not done for
Old Mar 7, 2009 | 10:42 AM
ef jay's Avatar
You won't be able to unbolt the doors, I tried. The limitting strap, or what ever it's called, won't let you pull the door off the car even after the hinges are unbolted. The door panel will come off, you will have to get a little ruff with it but don't worry it will be okay. I was able to remove my door panels will all the trim still on. Try starting on the top of the door panel. Make sure to remove your window crank. I only mentioned it because it's still on in the picture. I spent two days trying to figure this out. You can reach the child lock with just the top portion of the panel off, so start on which ever door worked from inside. Hang in there buddy, don't give up!
Old Mar 7, 2009 | 10:48 AM
jdmed3's Avatar
can ya give me a somewat walk through wat you did then please my interior is mint and i wana keep it that way but i dont wana have to move my seat everytime someone goes to get inside especially when im done making my harness bar
Old Mar 7, 2009 | 11:00 AM
ef jay's Avatar
I pulled the panel off starting at the top. Like I said you have to pull hard. You can take it slow and not break anything. Is the window crank off? You have to pull up to get the lip of the door panel over the frame of the door. Once the top is loose, you can work your way around. I know the door panel overlaps in the front but it will still come out. I still think the best way would be to start at the bottom towards the back. you will only have to pull hard enuff to release the door clips. If you break some, and you might, I have some spares. I can take pics but I'm at work right now and won't be home until six more hours.
Old Mar 7, 2009 | 03:51 PM
jdmed3's Avatar
Ok i will attempt this where are you located and cant i get the clips from a dealership incase i need new ones and it looks haggard with a ziptie
Old Mar 7, 2009 | 11:58 PM
~sp33~'s Avatar
EFB055
Worst case is that you cut the door card.
Old Mar 12, 2009 | 11:36 PM
jdmed3's Avatar
bumpin i pulled my motor and will have pics posted tomorr like 6
interior is saturday's project and i got ALL day to do this and alot more tools so be done soon makin a full build thread too
Old Mar 13, 2009 | 01:17 PM
ef jay's Avatar
I would think you can still get these clips for the dealership, but I have not tried. As far as where I'm located, that would be Artesia New Mexico.
So did you ever get the panels off and your doors working?
hotboxnaccord
Apr 21, 2011 05:46 PM
95civicdriver
Apr 7, 2010 06:26 PM
thomas998
Feb 2, 2010 07:45 AM
kkulseth
Jun 26, 2007 07:21 PM
rasta420
Aug 27, 2002 07:53 AM
