gsr lag on high rpm
Old Mar 5, 2009 | 02:41 PM
lilo_goki's Avatar
Default gsr lag on high rpm
what can cause a gsr to lag from 6k-8k rpm, my gsr lag on first gear, haven't taken it to second yet, but it lags from 6k-8k but low end is strong. i just did a head swap as well. could it be the valves are too tight?
Old Mar 5, 2009 | 04:03 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: gsr lag on high rpm
Tight valves tend to affect the low RPM range. Did you connect the IAB on the manifold?
Old Mar 5, 2009 | 06:56 PM
lilo_goki's Avatar
yes, i did, the iab is the little black box under the manifold right?
Old Mar 6, 2009 | 03:24 AM
Dogginator's Avatar
Daisy... Daisy...
Do you hear it open at ~5750 RPM? It provides no feedback to the ECU, so a malfuntion would not trip a CEL.
Old Mar 6, 2009 | 07:21 AM
mouab18c1's Avatar
check your timing with a timing gun if you just did a head swap
Old Mar 6, 2009 | 08:46 AM
1SicLS's Avatar
maybe the valve aren't seating why did you change the head?
Old Mar 6, 2009 | 01:47 PM
lilo_goki's Avatar
timing is correct, change the head because my 2nd cylinder on my old head was only 130psi while the others are 190 psi, after the head change, all my cylinders are now 220 psi all across, so i'm not sure what it could be.
laziebun
Oct 1, 2008 06:32 AM
H22powered_94teg
Apr 26, 2008 07:03 AM
rated_r
Feb 2, 2008 03:12 PM
hifonics
Mar 10, 2007 07:33 PM
Black R
11
Apr 19, 2005 08:24 AM
