Removing fuel line from fuel filter?
I soaked it in WD40 and went at it with a wrench and hammer for a good 30 mins. I can't seem to get the fuel line to budge. I don't want to heat it cause its a fuel line....
What methods did you guys use to loosen yours?
it would help to purchase a line wrench, cuz when theyre that tight, a normal open end wrench has a tendency to strip it out....once you get a line wrench, give it everything you got and expect a wonderful new slice on your hand when it gives....hopefully youre not a hand model.
I get it from below with a special tubing crows foot on a very long 3/8 inch extension. Sometimes with a soft 3/8s impact wrench gets it loose. It is very tight from the factory on the Accord. If it's a Civic, WD40 is not the best rust dissolving penetrant, try PB Blaster.
ODbuilt
Apr 26, 2014 12:50 PM
