No rear brakes
I started the original thread in the brake section back in January.
https://honda-tech.com/forums/suspension-brakes-54/no-rear-brakes-2477848/
It has had several suggestions but the problem is still there So I figured I would try it here.
Heres the details
1990 accord DX-non ABS, 280,000 miles, No pressure to rear wheels
Ice, snow, or gravel it will lock the fronts with relative ease, but absolutley will not lock the rears regardless of pedal pressure.
Brake pedal is high and solid, No air in system, new rear shoes, drums resurfaced. Wheel cylinders move when brake pedal is pressed with the drums off. E-brake works very well, The prop valve is a diagonal split type with one front and one rear running off each half of the MC so that rules out a bad MC. It seems like it got progressivley worse over the last year. I have been master certified for 10 years and currently work in a GM dealership on cars 10 times more complex than my accord so as you can imagine its pretty frustrating to be fighting this for this long. Any help would be appreciated.
Thanks
Nick
Heres the details
Thanks
Nick
Fluid level is always full. Never had to add any. I had a buddy push down on the pedal when the drums were off and both halves of the wheel cylinder moved fine. Any other ideas???
Nick
Nick
How are the drums and shoes? It seems to me that perhaps the problem might lie in the hardware in the brake drums. If the wheel cylinder seems to work and push the brake shoes with the drum off but will not work when the drum is on, then perhaps there is a restriction on the brakes with the drum on it or something (whether it be springs or the backing plate)
How is the wheel cylinders? I know you said that they push the brakes out when the drum is off but that does not mean that they are not bad, there is less pressure on the cylinders when the drum is off.
Also don’t rule out the Master Cylinder because the prop valve seems to be in order. I had one come in the shop back when I was a tech that had no brakes on the right rear wheel and even though the prop valve checked out correctly and the corresponding front one worked perfectly. In the end it turned out the master cylinder was the culprit and after replacing it, the brakes worked as should.
So don’t rule out the MC
Good luck
L
Good luck
L
Good luck
L
Good luck
L
Nick
Yea, the parking brake works good. Here lately on snow and ice I have been using the e-brake with the foot brake so at least all 4 tires are braking.
Nick
Nick
well i am no expert but i know that there really isn't too much to a non abs brake system in general, but if you have checked the lines and pads and stuff and there is no leaks than yeah it sounds like your MS
civicex442
Apr 24, 2007 04:37 PM
