New to honda tech... Just bought a CD
Hello!
I just bought this car yesterday...
Accord coupe LX
5speed
it has a f22b vtec motor
the solinoid is riddged with a yellow wire running to the ecu
(ecu p08 )
the yellow wire is wired to a red wire that connects to the ecu...
now when i drive the car it seems like it has no power what so ever...
i am looking towards a swap h22 later but for now i need help with this?
is the ecu good for this car? vtec wiring? i have no idea what this guy did before!
please help!
if more details are needed please ask
Accord coupe LX
5speed
(ecu p08 )
please help!
do u think he didnt update the engine harness wiring completly?
why would he put that yellow wire if the ecu is for that motor?
the wire is making contact to both the soilidon and the red cable in on the ecu
I hope this help's you
Connector A
Pin #
Name
Signal Type
A4
VTEC Solenoid Valve
Analog
A21
Ignition Control Module
RPM
A24
Power Ground
Ground
Connector B
Pin #
Name
Signal Type
B10
Vehicle Speed Sensor
Speed
Connector C
Pin #
Name
Signal Type
D2
Brake Switch
Analog
D6
VTEC Pressure Switch
Analog
D11
Throttle Position Sensor
Analog
D13
Engine Coolant Temperature Sensor
Analog
D14
Primary 02 Sensor
Analog
D15
Intake Air Temperature Sensor
Analog
D17
MAP Sensor
Analog
0.32V @ -13.9 PSI
4.84V @ 10.94 PSI
Connector A
Pin #
Name
Signal Type
A4
VTEC Solenoid Valve
Analog
A21
RPM
A24
Power Ground
Ground
Connector B
Pin #
Name
Signal Type
B10
Speed
Connector C
Pin #
Name
Signal Type
D2
Brake Switch
Analog
D6
Analog
D11
Analog
D13
Analog
D14
Primary 02 Sensor
Analog
D15
Analog
D17
MAP Sensor
Analog
0.32V @ -13.9 PSI
4.84V @ 10.94 PSI
