Your Opinion on Paint Gun...
Old Mar 5, 2009 | 04:25 AM
suthernbred904's Avatar
Icon2 Your Opinion on Paint Gun...
Im looking for people's opinions on what they have used or heard of being a great paint gun thats affordable. And can i just buy one gun to primer/paint my hatch or do I need two?
thanx,
mike
Old Mar 5, 2009 | 09:59 AM
Default Re: Your Opinion on Paint Gun...
bump for advice
Old Mar 5, 2009 | 10:32 AM
baz5453's Avatar
i use the devilbis gti gravity feed guns. and the devilbis pri primer gun.
you can get away with just using the 1 gun but you will need to make sure its well cleaned inbetween using dif products etc. all thoe if u can afford it u are better having a gun for primer,gun for base coat and a gun for clear coat.
i have used the sata jet aswell but was expensive too buy over here
Old Mar 5, 2009 | 10:38 AM
j_bizach's Avatar
All ive ever used is a sata. Having a gun for primer and paint is nice but not nessicary you just need to make sure that you adjust between steps (each product sprays different) and make sure that its super clean before you spray next product.
Old Mar 6, 2009 | 03:06 AM
i appreciate it alot guys!
thanx,
mike
Old Mar 6, 2009 | 03:45 AM
what do ya'll think about this set up? is it good enough to paint my eg hatch?
DeVilbiss
StartingLine HVLP Gravity Spray Gun Kit
part #: DEV-802342
• Auto Painting & Touch Up System
• Full size HVLP spray gun, 1.3mm fluid tip
• Mini HVLP detail gun, 1.0mm fluid tip
• Air adjusting valve
• 1.5mm primer set-up
• Molded case, accessories
Old Mar 6, 2009 | 03:46 AM
mind you, im doing all the body work, primer,etc.!
in my own garage...
Old Mar 6, 2009 | 04:09 AM
And is this a good setup to use, without any issues with fill up time?I appreciate your advice and opinions, this is my first time and i want to do it right!
thanx,
mike
Craftsman 26 gal. Air Compressor with Air Tool Kit, 1.6 hp, Vertical Tank, 160 Max PSI,
SCFM Delivery:
SCFM Delivery At 40 psi: 6.3 SCFM
SCFM Delivery At 90 psi: 4.9 SCFM
Tank:
Compressor Tank Capacity: 26 gal.
Compressor Tank Pump Style: Oil Free
Old Mar 6, 2009 | 05:07 AM
5GVTEC's Avatar
DeVilbiss
part #: DEV-802342
for $30 more you can get the primer gun too, fyi
Old Mar 6, 2009 | 06:55 AM
ohh ok, thanx(as a kit)
Old Mar 6, 2009 | 08:06 AM
precisionsc54's Avatar
Astro has a nice kit. Comes with 2 guns for like $120. And that compressor is small for an entire car paint job
Old Mar 6, 2009 | 08:22 AM
Astro, i'll check it out thanx. And the compressor is too small for an eg hatch? damn! What size and brand do think would work or if you have a link.
thanx,
mike
Old Mar 6, 2009 | 09:02 AM
92cxturbo's Avatar
I would get a cheap primer gun someting with a 1.6 or 1.8 tip would suffice, you dont want chuncks of pimer in your paint. Cheap guns sometimes leave more orange peel then good ones, unless you really know your paint product, and skillz, well it takes alot.....
Old Mar 6, 2009 | 09:05 AM
92cxturbo's Avatar
I'd like to see some paint jobs done with that kit..... I'd wouldn't use those for paintin anything else but small parts...
this is actually not that bad of a gun if you looking for cheap, not the best, but for the price pretty good IMO.. http://www.autobodytoolmart.com/pc-1...-kit-m707.aspx
Old Mar 6, 2009 | 09:06 AM
baz5453's Avatar
main thing is too make sure all the prep is done too as high a standard as possible as at the end off the day the paint can only go on as smooth as the preped panel. last thing u wont is scratches or ripples etc in trhe boddy work showing threw.
the compressor u got will run out air before u get around the full car id say ud need to keep stoping too alow it too build up air
Old Mar 6, 2009 | 09:19 AM
92cxturbo's Avatar
x10! a quailty paint job in mostly in the prep work..
Old Mar 6, 2009 | 09:33 AM
thanx guys, anyone have any suggestions on compressors that you have worked with or heard that are pretty sufficient? Has anyone used this kit:DeVilbiss
part #: DEV-802342
Old Mar 6, 2009 | 10:38 AM
http://www.spraygunworld.com/product...20QULauto4.htm
Old Mar 6, 2009 | 10:39 AM
h22ej8's Avatar
Sata for base, Iwata for clear, and dont look back.
Two of the best guns i've ever used.
Old Mar 6, 2009 | 10:58 AM
92cxturbo's Avatar
He said affordable, not most expensive.
Old Mar 6, 2009 | 11:32 AM
lol...ya'll have been alot of help, thanx! Lastly any links on good places to order primer,base coat, and clear coat from? And perhapse some reliable product names.
I know im asking alot of questions but, hey gotta learn from other people's experiences...plus it puts alot ya'lls knowledge to some use in this forum! lol
again thanx,
mike
Old Mar 6, 2009 | 12:22 PM
baz5453's Avatar
what colour is it you are going too paint it?
Old Mar 6, 2009 | 12:38 PM
h22ej8's Avatar
They both seem pretty affordable to me, it was well worth the buy IMO.
Old Mar 6, 2009 | 12:56 PM
baz5453's Avatar
the sata jet digital guns here sell for around £450 whichis around $800 odd .
great guns but pricey here
Old Mar 6, 2009 | 03:46 PM
92cxturbo's Avatar
Never said it wasnt worth the money as I own both of there guns but I also paint cars for a living.
