fidanza flywheel
ok so i bought a flywheel off ebay that was supposed to be a clutchmasters but when i got it, it was a fidanza. anyways my question is when i tried to put my clutch on the flywheel the little stubs that stick out of the flywheel dont line up to the pressure plate holes
so should i take those metal stubs off and just bolt on the clutch or do i have the wrong flywheel? if you every had a problem like this lmk thanks
Both Clutchmasters and Fidanza use a friction plate on their flywheels, they could be using the same flywheel, who knows. And the pressure plate i think will only go on one way maybe so you just gotta keep rotating it until it lines up.
The dowel pins center the pressure plate, !!!!!Do not remove them!!!!!! if you do especially with the rpms Hondas turn your clutch will probably come apart on you.
he is 100% correct
i have that flywheel and a pressure plate WILL line up but it will only do so one way. do not remove those pins !
spin the plate until it lines up and make sure you loctite the flywheel bolts
btw clutchmasters just reboxes fidanza which is probably the best ultra light aluminum flywheel we can get.
so today i tried at it again and i still couldnt get um to line up where you screw the pressure plate bolts. I tried moving the clutch around and there is one spot that almost lines up the holes but still not good enough to bolt down
i will post a pic to show do you guys think i have the wrong flywheel because i tried 3 different pressure plates with the same results i have a b series btw thanks for the help
Don't remove the dowel pins since they are there to keep it centered and balanced. If you grind them off your flywheel and pressure plate may be off center, it will cause more headache to custom fit it that its worth. It's possible that an ebay seller sent the wrong item.
luderone
Sep 13, 2003 02:01 PM
