just got my jdm b18c5 today!!!
i just got my type r engine today. while the engine is out, should i do anything to it? i was thinking of putting in some jun or toda cams. what should i do before i put it in???
nice, yes put some cams up in there and sell the ITR cams
since you are asking i would just ASSUME u don't know much, i'd have a pro install those cams for you heh
btw where did u order the motor from?
clutch, flywheel and maybe a 4.785 final drive. Give it a good cleaning to!
I cant wait till i get mine... one of these days.
You could always pull the head off and inspect everything, make sure u dont have any bent valves or bad pistons. While ur at it throw in some CTR pistons and new rings.
[Modified by Downeybear11, 7:41 PM 8/11/2002]
I cant wait till i get mine... one of these days. You could always pull the head off and inspect everything, make sure u dont have any bent valves or bad pistons. While ur at it throw in some CTR pistons and new rings.
If it's a JDM B18C SpecR motor with tranny then it already has a 4.785 FD.
I cant wait till i get mine... one of these days. If it's a JDM B18C SpecR motor with tranny then it already has a 4.785 FD.
How many miles on it? I bought my GSR swap @ 61k miles. I changed my water pump and timing belt for the heck of it since it was easy to get to.
Just drop it in. Test it out and see how it runs.
If all is well...then start modding.
i don't know too much about type r's, just their specs. i mostly researched on LS's cause i was going to boost my LS. but i just couldn't help it, i had to get the b18c5. i bought it from hondamotorsonline.com
yeah its a jdm b18c5, the guy i talked to said it was a 98'
Technically it's a JDM B18C SpecR. Not a B18C5.
BTW, what was the pre 98 JDM R's FD?
1. jdm ITR motor is not a b18c5. its just b18c. if your block says b18c5, then you got ripped.
2. 98+ spec jdm ITR motors come with a 4-1 header opposed to the 95.5-97 4-2-1.
3. 98+ spec jdm ITR motors also USUALLY come with the carbon kevlar spark plug wire cover.
4. 98+ spec JDM ITR comes with a 4.785 FD opposed to the 4.4 FD
5. check the head stamp above the header to check what year it is.
6. you can also find out by the number under the "b18c".
98+ JDM ITR spark plug covers have the same faux c/f pattern as the interior trim pieces.
