how to get get CEL codes with obd0/1 jumper harness?
Old Mar 4, 2009 | 07:59 PM
johnwohl's Avatar
Default how to get get CEL codes with obd0/1 jumper harness?
Hey, I need to know how to get the CEL codes from a P28 in a mini me setup where i'm using an obd0 to obd1 jumper harness. I see one wire that is marked CEL and i thought all I had to do was ground that wire, I dunno though, it's not working, am I doing it wrong?
Old Mar 4, 2009 | 08:53 PM
relo's Avatar
Default Re: how to get get CEL codes with obd0/1 jumper harness?
who,s jumper harness r u using eg company
Old Mar 4, 2009 | 09:01 PM
thisiskev's Avatar
you have to keep it connected to the ground. usually its a yellow wire on most jumper harness's.
Old Mar 4, 2009 | 09:27 PM
relo's Avatar
all the one,s i use have the yellow wire as the mil so i say toggle switch it too ground
Old Mar 4, 2009 | 11:15 PM
johnwohl's Avatar
hrm, I did ground that wire and it didn't change anything. I don't have to start the car to see the code do I? I mean, it should just start flashing with the ignition in the on position with the car off shouldn't it? maybe im not using a good ground.
it's an ebay jumper but i did go through and verify all the pins are correct with this:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d-i-y-faq-obd-0-obd-1-pinouts-conversion-help-1319235/
also, I just read a guide saying that you need to connect the a13-MIL wire to the d04-SCS wire, I don't know what SCS stands for but I'm going to try that in the morning. I'm pretty sure the wire I've been trying to ground is the a13-mil wire, I guess I should have made a note of it but I think thats right.
anyone have any other tips or know what that SCS wire is?
edit: also i found that some harnesses use the ignition timing jumper plug to activate the CEL light, I don't think this one is wired that way but I'll try that too.
Old Mar 5, 2009 | 03:12 AM
sleepingciv's Avatar
scs is for eg **** idk what it stand for sorry
u need to ground out D04 coming outta the ecu
when i sell mine i inclued a toggle switch for this purpose
Chaosgrunt
Mar 13, 2019 06:23 PM
cardinalboy07
20
May 1, 2012 09:25 AM
gohdunlam
16
Jan 20, 2010 12:22 AM
Hondamonster
Jun 10, 2007 12:46 AM
SLeePeR012
Nov 8, 2003 07:01 PM
