91 EF hatch with obd0 b18a1 swap probs.!!
I can't figure out why it wont start.
Here's a list of the mods.
motor and transmission
B18A1
stock LS head
GSR crank
GSR rods
TYPE R pistons
GSR water pump
GSR oil pump
GSR oil pan
GSR new timing belt
new head gasket
new valve cover gasket
new thermastat
new dizzy
new starter
new oil
new oil filter
new oil pan gasket
hasport motor mounts
LS tranny
brand new stage 1 clutch kit
converted to multiport
pr4 ecu
suspension
tein springs
red kyb shocks in the rear
stock shocks in the front
exterior
rattle can black
amber corners
interior
plad head liner
gutted rear interior
LS seats
CRX Si cluster
excalibur alarm
no cd player
has door speakers
keyless entry (not hooked up but has relays and actuators)
The fuel pump clicks on, but it just cranks. I'm pretty sure everything is wired right, but any ideas would greatly help. Thanks!
B18A1
stock LS head
GSR crank
GSR rods
TYPE R pistons
GSR water pump
GSR oil pump
GSR oil pan
GSR new timing belt
new head gasket
new thermastat
new dizzy
new starter
new oil
new oil filter
new oil pan gasket
LS tranny
pr4 ecu
suspension
tein springs
exterior
rattle can black
amber corners
interior
plad head liner
LS seats
CRX Si cluster
excalibur alarm
no cd player
has door speakers
Check for faults, see what you have report back. Another thing, show me the wiring schematic that you used to do the multi-port conversion. 100% positive your problem is in there.
fires, sprays fuel. then uhhhhhh yea it's timing or a missfire somewhere. check your dizzy cap too. always the dumb things, like they said, check firing order as well, don't get too smart ahead of yourself, you might of over think something. my 2cent
wunfstgsr
Apr 12, 2012 09:35 PM
