anybody know how to line up the cranks for the timing belt?
Old Mar 4, 2009 | 03:24 PM
bigredram's Avatar
Default anybody know how to line up the cranks for the timing belt?
put a cam in, and it was missing, so I think when i put the belt on it was slightly off, I worked on it today, and only made it worse, wont start now. I cant find where to line up the bottom crank?
Can anyone help me?
Old Mar 4, 2009 | 06:04 PM
DoubleEx's Avatar
Default Re: anybody know how to line up the cranks for the timing belt?
you have to take the crank pulley off and there is a mark on the crank gear and block. Make sure you buy the crank holding tool from amazon.com its cheaper or you will never get the bolt loose.
Old Mar 4, 2009 | 06:54 PM
p10hlm's Avatar
cranks!!
Old Mar 5, 2009 | 04:21 AM
fireant's Avatar
It would help if you told us what motor you were talking about.
Old Mar 5, 2009 | 04:45 AM
DoubleEx's Avatar
should not matter, should be same for all mark on crank gear and block
Old Mar 5, 2009 | 07:01 AM
Solid Motorsports's Avatar
Make sure you're aligning with the right mark on the head too.
For the D15B1, align the cam gear 90 and 270 deg marks with the head surface. For the D16A6, align the cam gear's single mark (at ~210 deg) with the mark on the upper side cover.
Old Mar 5, 2009 | 07:02 AM
bigredram's Avatar
any way to get the pulley off, the bolt doesnt budge at all. dont want to buy a special tool just for that
Old Mar 5, 2009 | 07:06 AM
jlicrx's Avatar
Old Mar 5, 2009 | 12:26 PM
DoubleEx's Avatar
either have to have a special tool for that bolt or a strap wrench to hold pulley and a heavvy duty breaker bar. When i did the timing kit on my wifes 01 civic i broke a snap on extension and a 19mm deep impact socket.
Old Mar 5, 2009 | 01:04 PM
4drEF's Avatar
Keyboard Humorist
If you live in a snow or rust area then good luck without the tool.
Maybe heat it up for a few minutes with a torch and maybe that will expand and break free a bit when it cools down.
I've been luck with jamming the flywheel.
I use a 1/2 drive flex handle- not a ratchet (tried that... broke ratchet a couple times.
With the flex handle, I connect to the shortest exenstion I can to clear the fender and then i put a long pipe on the handle. I think the pipe is about 6 feet long.
Just straight and steady force - no bouncing or jerking on the bolt!
Old Mar 5, 2009 | 02:18 PM
OSR*EF4DOOR's Avatar
There should be a make on the block an the pulley
i just did mines today with a single pulley so i dont have a/c or p/s ..it wasnt that bad
No make...mark
Old Mar 7, 2009 | 11:40 AM
bigredram's Avatar
So It still wont start, found all the marks and lined them up, Getting fed up with it now! I took the plugs out b/c i wanted to see if i flooded it, and my 3 of my plugs were soaked in oil, what could this be from?
Old Mar 7, 2009 | 11:51 AM
thedudefromjerz's Avatar
maybe valve seals
Old Mar 7, 2009 | 12:36 PM
bigredram's Avatar
It ran fine a week ago, when i put the cam in I took the plugs out and they were fine. I dont think they could go bad in a week of it sitting in the paking lot. Ive been doing some reading, and have learned that if the timing belt breaks or is very far off, then the valves can get bent, could this be the problem, if so how do i fix it?
Old Mar 7, 2009 | 12:41 PM
bigredram's Avatar
I just want it to run again, Im thinking about putting the old cam back in.
All i did was swap a d15b1 cam with a b2. didnt think it was a big deal, maybe i was wrong
PY2KITR1060
Jul 26, 2022 06:12 AM
foolsforever
11
Aug 9, 2018 05:08 PM
goota
Aug 22, 2009 07:38 AM
JRciv
Nov 22, 2004 01:58 PM
spyderracing
14
Sep 26, 2004 09:10 AM
