Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Civic - HID Installation Help
Old Mar 4, 2009 | 02:55 PM
bce22's Avatar
New User
Default 03 Civic - HID Installation Help
Good Day everyone:
I recently purchased an apexcone HID Kit. It came with the standard plug and play wiring harness as opposed to a separate relay harness.
Now The Kit includes obviously the ballasts and the bulbs. The bulbs have a male and female connector to connect to the ballast (simple enough) and the ballast has a separate male wire to connect to the existing OEM bulb connector. The standard three prong connector that plugs directly into halogens.
I have a low beam only setup so the male end from the ballast only has 2 prongs instead of three.
Now the problem is when I hook it all up......NOTHING HAPPENS. I get no lights at all.
No I am not a complete idiot here. To be honest it doesn't look like it can be setup any other way. I have tried both ballasts and both bulbs and nothing.
What am I missing? Any advice at all?
Thanks in advance,
Brad
Old Mar 4, 2009 | 06:33 PM
LFSoccer2k6's Avatar
Default Re: 03 Civic - HID Installation Help
this happened once to my friend. Sometimes the connectors are switched around in the car so you are actually not touching the right polarizations together. take the connectors out of the black thing and switch them around. i could be wrong though.
markeke3
Lighting
Oct 12, 2012 12:41 AM
btcca4
Audio / Security / Video
Jan 31, 2005 12:22 PM
EMphaticONE
Mar 28, 2004 04:00 AM
GhettoBrawls
Jun 28, 2003 09:09 AM
