ebay "timing advance kit"
Old Aug 11, 2002 | 05:14 PM
TerdFerguson's Avatar
Default ebay "timing advance kit"
I was doing my normal browsing on ebay and found a timing advance kit for a civic. It sounded good at first, but after reading some negative feedback i found out that its nothing more than a little resistor that you tap into a sensor. Supposedly it tricks the engine into thinking that it is getting cooler air, and therefore advances the timing. I was just wondering if anyone has tried anything like this, because im still kinda curious.
Old Aug 11, 2002 | 05:35 PM
speedymon's Avatar
Default Re: ebay "timing advance kit" (TerdFerguson)
It could cause engine damage. Do you know what too much advance on an engine will do?
Old Aug 11, 2002 | 05:39 PM
MooreBoost's Avatar
Default Re: ebay "timing advance kit" (speedymon)
What?
gmoore
Old Aug 11, 2002 | 06:12 PM
hondafrk's Avatar
Default Re: ebay "timing advance kit" (gmoore379)
DETONATION, bbbbbbbooooooooooommmmmmmmm!!!!!!!
Old Aug 11, 2002 | 10:06 PM
Default Re: ebay "timing advance kit" (hondafrk)
well i think the timing is advanced some when the car is first started, and i know it runs richer at that point........i think the idea is to try to keep those settings at all times, and not just warm up.....but who knows, i just thought it would be fun to screw around with and accidentally knock .01 seconds off my time.
Old Aug 12, 2002 | 05:11 AM
jweller's Avatar
I'f you are going to **** with it, use a potetiometer instead of a resistor. a potentiometer or a pot, is basically a variable resistance resistor. so you can change it around if you need to. Of course you increase the chance of bad things too
mortificationrock
10
May 8, 2008 01:51 PM
wytechoppin
Feb 28, 2007 05:52 AM
kornerk12
Dec 18, 2005 03:16 PM
Turbo Powa
16
Jun 3, 2002 06:02 PM
