mounts and hydro conversion
Old Mar 4, 2009 | 01:18 PM
streetsold6teeny8's Avatar
Default mounts and hydro conversion
IF im using innovative mounts for a b series swap with a hydro tranny can i use the hasport clutch actuator (not master cylinder conversion) with it and vice versa hasport mounts with innovative clutch actuator..
Old Mar 4, 2009 | 02:16 PM
DARKB20's Avatar
Default Re: mounts and hydro conversion
why not just use innovative mounts with innovative clutch actuator or hasport mounts with hasport clutch actuator..... BUT if you must use one brand part with the other brand part it should be ok... the motor sits almost the same.......
Old Mar 4, 2009 | 02:39 PM
because i get the hasport clutch actuator cheaper than the innovative.. and the innovative mounts cheaper than hasport... weird but its what i can get
raverx3m
Feb 26, 2015 10:48 PM
i-VTEC racer
Oct 29, 2014 04:38 PM
russianswty
21
Oct 16, 2006 05:48 AM
everidge4
Apr 2, 2004 07:30 PM
26
Apr 30, 2002 05:39 AM
