code 15 Ignition OutPut Signal!! How do I rewire?? Have a few questions
Old Mar 4, 2009 | 08:48 AM
Fuk SALT's Avatar
Banned
Default code 15 Ignition OutPut Signal!! How do I rewire?? Have a few questions
Okay.. Ive looked everywhere for the problem! I cant find where the wires are F'ED up.. I was thinking about rewiring the ignition output signal wires (if this is possible?).. Can some please give me a thread or something to help me know where the wires run to? from the ignition to ecu to distributor?? or however they go.. and wat color wires they would be?? thank you
Old Mar 4, 2009 | 09:17 AM
jlicrx's Avatar
Default Re: code 15 Ignition OutPut Signal!! How do I rewire?? Have a few questions
do you by chance have an HF and are trying to use an Si engine harness? if so, that is your problem with the igniter code 15 - the HF chassis harness has the igniter wire in the connector at the driver's side where the Si has it in the connector at the passenger side - that won't be your only problem as the firewall connectors at the driver's side have all of the wires in different locations from the Si - engine harnesses are not interchangeable
the igniter wires are the black/yellow in the 2-wire distributor connector which comes from the ignition switch and the thick white wire in the round 7-pin connector at the distributor which splits into 2 wires inside the harness and runs to ECU pins B15 and B17
Old Mar 4, 2009 | 10:42 AM
Fuk SALT's Avatar
Banned
I DO HAVE AN HF!! wow THANKS ALOT MAN!! THIS IS SOMETHING I DID NOT KNOW! i have an SI engine harness! i get spark when i use MY HF one but i throw codes 6 and 10 and the check engine light stays on the whole time and it wont start.. i dunno wats wrong with it
Old Mar 4, 2009 | 10:45 AM
Fuk SALT's Avatar
Banned
so wat is it that i need to do? can i use my SI Harness and reroute some wires??? or do i need to switch back to my hf harness and figure out wats wrong with that??
Old Mar 4, 2009 | 11:07 AM
jlicrx's Avatar
does your HF engine harness still have the connector for the EGR valve?
Old Mar 4, 2009 | 11:16 AM
jlicrx's Avatar
you could try re-pinning the Si harness - go here:
https://honda-tech.com/forums/showth...engine+harness
Old Mar 4, 2009 | 12:09 PM
JoshJosephKeith's Avatar
thanks alot man.. this is "f- salt" my sn got banned do to the "f word" being in my sn which i think is pretty lame. But anywas.. which wire is the wire off the disty that i need to cut? is it in the 2 wire connector on the disty??? because I know there is 2 white wires that run through the big connector on the disty? would it be them?
Old Mar 4, 2009 | 12:46 PM
bump.. another question.. MY NEUTRAL SAFETY SWITCH IS broke.. the sensor.. is there a way i can just wire this to stay on.. ???
Old Mar 4, 2009 | 02:01 PM
my car JUST STARTED FOR THE FIRST TIME!! NO CODES WHATSOEVER!!!! CODE 3 FOR MAP SENSOR BUT THATS because i didnt plug it in!!
Old Mar 4, 2009 | 02:40 PM
jlicrx's Avatar
just connect the 2 wires together - just don't forget that it will start without the clutch pedal depressed
Old Mar 4, 2009 | 02:47 PM
alrite good deal. easy fix. yea i wont forget.
Ryan.
Apr 29, 2008 11:48 AM
eth0r
Apr 23, 2007 06:19 AM
cjwarren4dcivic
14
May 1, 2006 11:25 AM
UNDER PRESSURE
Nov 21, 2005 02:19 PM
CiViC SiR
Jun 26, 2003 07:07 AM
