kill switch?
Old Mar 4, 2009 | 08:44 AM
pimpdd101's Avatar
Default kill switch?
i hooked up a kill switch to the ecu fuse under dash (hot in run and start) will it afect ecu or hurt the motor trying to start with no ecu on? and it got a MIL it was the code 9 (cyp) in the dizzy. could that be from kill switch
Old Mar 4, 2009 | 08:50 AM
locosiete's Avatar
Default Re: kill switch?
well if you didn't have one before you did it i would say yes. and there is other killswitchs you can do that are just as effective that don't involve messing with your ecu
Old Mar 4, 2009 | 08:56 AM
TouringAccord's Avatar
H-T Order of Merit
i agree, like a kill for the fuel pump
Old Mar 4, 2009 | 09:16 AM
locosiete's Avatar
yeah i just read suspendedHatch thread on that looked pretty easy to me and MUCh more effective
https://honda-tech.com/forums/audio-security-video-27/%5Bhow-%5D-car-security-1794938/
Old Mar 4, 2009 | 07:15 PM
uberEFtuner's Avatar
Unhooking the ECU is a bad idea. The ECU stores data using the battery power.
Old Mar 4, 2009 | 09:39 PM
alkoholikwun's Avatar
this was my old setup a few years ago too, but i encountered one problem, it would take the car 2 times to start up whenever i turned the engine off and the car sat for a while. i guess the 1st time starting it got the fuel going, but not enough, and the 2nd time starting got all the fuel completely pumping.
probably wired up something incorrectly.
Old Mar 5, 2009 | 02:10 AM
jwicecold's Avatar
Ive heard of that problem with the same setup.. But what is the point of hookin up a kill switch??
Old Mar 5, 2009 | 02:20 AM
locosiete's Avatar
just a cheap way of making sure someone don't steal you car. Yeah they might get your stereo and stuff but at least you still have your car
this way if your car isn't getting gas because you turned off the fuel pump they aren't going anywhere with that car
Old Mar 5, 2009 | 06:11 AM
H-T Order of Merit
I haven't heard of that before nor have I experienced it either.
Old Mar 5, 2009 | 06:13 AM
H-T Order of Merit
I wouldn't say it'll "make sure someone don't steal your car" but it could slow them down which is all you can hope for. Layer your security to slow them down enough that hopefully they give up. If someone wants it bad enough though there isn't much that is going to stop them.
Old Mar 5, 2009 | 07:46 AM
locosiete's Avatar
well u r correct if someone wants it bad enough it is gone. here is no 100% guarantee to avoid car theft but a well placed kill switch is the closest thing. the key is to place it somewhere only you know how to access it and not in plan sight. unless you do some james bond stuff like the cruise on with the defrost on with the e brake set to activate the starter. yeah its a lot of wiring but it would takes someone for ever to figure it out assuming you didn't cut the wires in a obvious place or at a location where not normally accessible
3k1n
Engine Management and Tuning
Nov 14, 2012 10:23 AM
fryman
10
Sep 11, 2009 07:01 PM
no1knows908
Apr 21, 2008 10:35 PM
jadugartir
17
Dec 18, 2006 05:38 AM
eLeCtRoNSi00
Apr 16, 2004 01:17 AM
