SRS light for pass airbag... But no airbag!(98 CX)
Old Mar 4, 2009 | 12:54 AM
Hung_Lo's Avatar
Default SRS light for pass airbag... But no airbag!(98 CX)
Okay, so I buy this 98 Civic CX. Has SRS light on it.
I run the code and get 2-2 (increased resistance on passenger airbag)
The messed up thing is: I DON'T HAVE A PASSENGER AIRBAG!
There is a cover for the pass airbag that looks stock. I looked underneath, there is nothing there. No traces of wiring, no nothing.
What is up with that? Oh yeah, the drivers airbag looks fine.
Old Mar 4, 2009 | 01:52 AM
Inliner's Avatar
Default Re: SRS light for pass airbag... But no airbag!(98 CX)
maybe youve got a ex srs computer??
Old Mar 4, 2009 | 01:53 AM
Davus's Avatar
Previous owner got rid of the airbag and put in a block off plate? Surely even CX's come with passenger airbags, but I'm not sure. If not, different SRS computer. There'll be a connector right around the cupholder/climate control for airbag: You can either jump this with a 2.2 ohm resistor to make the SRS believe there's an airbag there, or bolt in a passenger airbag and wire it up (should clip in).
Old Mar 4, 2009 | 05:05 AM
gsrturbo-ek's Avatar
yea your missing the pass side airbag
i have bunch of the resistors needed to trick the srs computer to think you have a airbag
Old Mar 4, 2009 | 05:20 AM
94EG8's Avatar
Seagull Management
What country are you in? The Canadian CXs didn't come with a passenger's side airbag in '96 for sure, I'm not sure if that carrys all the way through the production line, or just that one year, but I can confirm for a fact that '96 models don't have it. (except canadian CXs with the option package) All US '96 - '00 civic regardless of trim level had dual airbags. US/Canadian refers to where the vehicle was originally to be sold, it does not refer to where the vehicle was built. All '96 - '00 hatches were built in Aliston Ontario.
Old Mar 11, 2009 | 10:08 AM
Hung_Lo's Avatar
Do you guys have, or no of a write up on how to do this?
Yeah, it's a Canadian base model.
I went to a junkyard and saw a bunch of CX model hb without airbags. I think the DX models(with tach) were the only ones with passenger airbags)
Kinda weird though, because my 94 had both driver and passenger...
Really weird that I have a code though. It doesn't look like the airbag was replaced on the other side either.
Old Mar 11, 2009 | 10:14 AM
redegboosted1's Avatar
Maybe it was crashed and the airbags deployed . Previous owner didnt find a need to replace passenger airbag and just bought a cover for it . My friend does that same thing at his dealer,but atleast he tells the ppl. Was the car crashed before? Run a carfax on the vin and find out . Be safe
Old Mar 11, 2009 | 10:26 AM
94redsi's Avatar
New User
car couldnt been crashed before and owner just put in a block off plate hence why the SRS light is still on it still thinks its there if you dont feel the need for a passenger airbag You can always just jump the connector to make the car believe that there is an airbag in there
Old Apr 6, 2009 | 01:28 PM
Hung_Lo's Avatar
1998 CANADIAN CX hatchbacks do not come with passenger airbags.
There is a "dummy resistor" that connects to the plug. I've been trying to locate it to no avail.
It's pretty frustrating. Anyone have any ideas where this connector is?
Old Apr 7, 2009 | 07:19 PM
bk0404's Avatar
just unplug the light then it should be solved....
Old Apr 7, 2009 | 07:24 PM
JarvisW's Avatar
Sol to Sol
^^ +1!!
Oh wait, unless they need to see it to pass inspection...
Hmmm
Old Apr 18, 2009 | 02:34 AM
Hung_Lo's Avatar
Easy fix.
The dummy resistor for the passenger side needed to be replaced.
$20 later from the dealership, 20 seconds of reset time, and it's GOOD TO GO!
Old Apr 18, 2009 | 02:36 AM
Davus's Avatar
Originally Posted by JarvisW
^^ +1!!
Hmmm
I'm curious how they would. Does the SRS light normally come momentarily on when putting key in ignition, like the CEL? (My clockspring broke.)
s1ngleslam
Dec 1, 2008 10:48 AM
bushco
Jun 7, 2006 07:09 AM
!xobile
Jan 24, 2006 09:01 AM
Rory Breaker
Aug 15, 2005 01:21 PM
yellow blur
Feb 7, 2003 10:10 PM
