Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
control arm replacement, which is cheaper?
Old Mar 3, 2009 | 09:45 PM
HondaCivic2006's Avatar
Default control arm replacement, which is cheaper?
Hello, I have a 2006 Honda Civic Si, that has a damaged right side rear arm.
I called the honda dealership and they gave a a price of $692.88 price and labor.
My question is, should i get it done at the Honda dealership, or should i buy the control arm off of ebay or something and have some independently owned shop replace it? Or is it a possibility that i could do the whole procedure myself, using just normal, store bought tools?
Old Mar 3, 2009 | 10:01 PM
pd0019's Avatar
Default Re: control arm replacement, which is cheaper?
i believe you can replace it yourself. try going to a junk yard and finding one
Old Mar 4, 2009 | 07:35 AM
Zeusone's Avatar
location?
Old Mar 4, 2009 | 08:49 AM
guinnessstout's Avatar
It isn't that hard to change, the only thing you will want to do is get it aligned after so don't do it and forget to align for a few days due to bad tire wear.
Old Mar 4, 2009 | 03:11 PM
inkong's Avatar
you can probably find a thread or page that will explain how to do the work
Old Mar 4, 2009 | 05:07 PM
anybody know a website where i can get it the arm cheap? as well as the procedure to do it? i need to know what i need if i were to do it myself.
Old Mar 5, 2009 | 07:37 AM
Zeusone's Avatar
where are you located? i can get you one for cheap.
Old Mar 5, 2009 | 01:24 PM
i live in the Monterey Peninsula. in California
Old Mar 5, 2009 | 01:27 PM
Kidnkorner's Avatar
car-part.com
majestichonda.com
hondapartsdeals.com
hondapartscheap.com
Old Mar 5, 2009 | 01:34 PM
Zeusone's Avatar
perfect. im in cali. let me see where i left set of arms i have. they were used for 1k miles.
Old Mar 5, 2009 | 05:46 PM
N4me (06civicsi)'s Avatar
Yoyo....I got a question for u guys I have this noise comming from my right side front wheel actually it sounds like its coming from under the dash its like a metal on metal noise when ever I hit a bump its driving me nuts.....my ? Is what symptoms did u have 2 kno what problem u had?
Old Mar 5, 2009 | 11:31 PM
well i really lucked out because my brakes were starting to squeak excessively, and my car shook a lot at highway speed, so i got a 4 wheel alignment and a brake inspection. and upon inspection they found (among other things) my rear arm damaged.
but what kind of noise is it? is it like a clank, or a screeching?
Old Mar 5, 2009 | 11:33 PM
awesome, let me kno soon, cause i'm gettin really uncomfortable driving the si around.
civic1234
28
Feb 18, 2010 08:27 AM
crxgator
Nov 21, 2004 12:42 PM
civiccpedx
15
Oct 19, 2004 07:57 PM
phreakmang
Mar 15, 2004 03:28 PM
