Revving Issue
Old Mar 3, 2009 | 07:09 PM
JDMproblem's Avatar
Default Revving Issue
Motor Specs:
Rebuilt D16A6
zc camshaft
aem camgear
9.5 cr pistons
lightweight flywheel
i/h/e
I have been having some issues with this motor lately and I cant seem to figure it out. The car runs fine but will redline @ 4500-5000rpms. I changed the computer and it still does the same thing. Could it be cause of the zc camshaft??
Old Mar 3, 2009 | 07:16 PM
thedudefromjerz's Avatar
Default Re: Revving Issue
check your sensors, map and tps
Old Mar 3, 2009 | 07:20 PM
JDMproblem's Avatar
will do
Old Mar 3, 2009 | 07:45 PM
JDMproblem's Avatar
any other suggestions?
Old Mar 3, 2009 | 09:31 PM
93formula's Avatar
are they wired up correctly? some have wired them up backwards, any codes? is the timing correct? did this occur recently? how are your plugs wires and dist?
Old Mar 4, 2009 | 08:13 AM
..NeRd..'s Avatar
I had this issue when I had my CRX. I did what you have done, and it ended it being my distributor believe it or not. It just happened from one day to the next. The guy that looked at it at the time replaced the igniter if i remember correctly. Hope this helps.
Old Mar 4, 2009 | 10:20 AM
CW-ITR's Avatar
Originally Posted by ..nerd..
i had this issue when i had my crx. I did what you have done, and it ended it being my distributor believe it or not. It just happened from one day to the next. The guy that looked at it at the time replaced the igniter if i remember correctly. Hope this helps.
x2
Old Mar 4, 2009 | 11:30 AM
JDMproblem's Avatar
Replaced, dizzy, plugs, wires, ecu, and checked wiring..but all were used parts, ill try gettin a new dizzy see if that changes anything
Old Mar 4, 2009 | 11:31 AM
JDMproblem's Avatar
and im gettin code 4, and occasionally code 1
Old Mar 6, 2009 | 11:38 AM
JDMproblem's Avatar
dano670
Texas -OK -LA (Sales)
Sep 29, 2011 06:41 AM
XplicitzOldSkoolDA
10
Aug 19, 2008 06:51 PM
h22_crx
Mar 19, 2006 12:20 PM
4g4me
14
Jun 8, 2004 11:40 AM
Speed_Ricer99
Feb 16, 2002 05:26 PM
