92 honda civic si engine code 43 & 15
Old Mar 3, 2009 | 03:18 PM
caspertxr's Avatar
New User
Default 92 honda civic si engine code 43 & 15
what can i do to get this problem solved
Old Mar 3, 2009 | 03:23 PM
dohcdelsol's Avatar
Default Re: 92 honda civic si engine code 43 & 15
check your wireing for 15. might have some lose wires.
as far as 43-fuel supply system i had that once before when it was brutally cold but it never came back. a short while later i got the o2 code. replaced the o2 sensor and the fuel supply code went away.
i'd check if you are getting power to the fuel pump or if the fuel pump bag is clogged and also check the fuel filter and replace it if needed.
Old Mar 3, 2009 | 03:35 PM
caspertxr's Avatar
New User
thanx u very much man ima go ahead and do that
str8JDMteggy
Sep 29, 2006 08:27 AM
essex
Jul 25, 2005 06:11 AM
PhilStubbs
Jan 22, 2005 11:20 AM
importimage
Jun 30, 2003 04:27 PM
