Vibration under acceleration
check the inner cv joints. grab the axle and twist it, listen for a clicking sound and feel for movement between the axle shaft and inner joint.
Check and see if both of your CV joints are free... if they are stiff, then they can create vibration during acceleration... Most of the time, the problem is from your outer CV joint, you can either rebuild them or buy new ones... hope this helps you out...
mingbling96
Mar 13, 2005 08:14 AM
