Power doors & windows not working! plz help
I swapped the harness on my 00 ek hatch so that I could use these new doors with power everything... does not work. rest of the car is getting power. harness is plugged in correctly as far as I know. unless theres some extra ones hidden somewhere. swapped motor and harness to b16a from a 00 civic si and took the doors and now im getting frustrated. someone said that it may be the fuse... i bought a new one, stuck it in.. still doesnt work.. whats the next troubleshooting step i should take?? thanks in advance
what details do you need? I parted out a 2000 si for my 2000 hatch. took b16a motor. swapped the whole harness so I could use the power doors and windows. so yeah, I took the doors too.. lmk what details ur lookin for. what would u want me to take a picture of?
i'm not sure since I don't have an EK, but are the power lock and power window control module boxes in the door or are they mounted under the dash?
did you install those?
Power windows:
Does your under dash fuse box have a power window relay?
Do you have fuses in slot 10, 11, and 24 under the dash?
Power locks:
Do you have the keyless door lock control unit behind the driver's kick panel?
Do you have fuses in slot 51 under the hood and slot 14 under the dash?
Power locks:
omg I'm goin to check all this stuff first chance I get thanks I'll let u know how it goes after the weekend
problem solved, one side was not grounded and the other side was not connected properly on the floor harness.. thanks for the help!!
hey im in the middle of this conversion, too.. i have the same car.. a 2000 dx hatch
my power windows work but i can't get my power locks to work. what kind of fuse do i need under the hood? also, what do i plug the door lock brain into.. i can't find anything on the harness that matches...
datkidjavi
12
Mar 8, 2009 04:43 PM
sevenfc
11
Jul 6, 2008 09:46 PM
I Still Love H.E.R.
14
Jul 22, 2007 12:43 AM
