grinding noise in rear...help
Old Mar 3, 2009 | 10:34 AM
jfarrar23's Avatar
New User
Default grinding noise in rear...help
i have an 02 civic Si and i recently have slid into a curb pretty hard and hit the curb with the tire now when i go over 30 i hear a grinding noise on the side i hit (rear driver side). it gets worse when i turn to the right sharply it sounds like something is rubbing. i know i didnt bend the rim because i changed it and it still makes the noise. i took a look at the axel etc. and nothing appears to be bent. what could it be? my grandpa who is ASE said it could be the wheel bearings?
Old Mar 3, 2009 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Default Re: grinding noise in rear...help
I'm with grandpa, or possibly brake caliper mounting bracket, or rotor, maybe the spindle itself, it has to be a moving part.
I would get the bearing, as it should be replaced anyway, smacking a curb with a wheel is not good for the bearing at all, then pull it all apart and find problem, if it turns out it is something differant then the bearing, replace the bearing anyway, just to be safe. 94
Old Mar 3, 2009 | 12:29 PM
SovXietday's Avatar
Could have pushed the dust sheild into the rotor too. Lots of things on this one, you'll need to pull it apart and investigate.
Old Mar 3, 2009 | 01:54 PM
philafelman's Avatar
if its a wheel bearing, it should get quiet when turning one way, and louder when turning the other way.
Old Mar 3, 2009 | 04:14 PM
fcm's Avatar
fcm
Old Fart
Forgot about that one, bonus for him if that's all it is. 94
Old Mar 4, 2009 | 09:41 PM
civic sand rail's Avatar
" i recently have slid into a curb pretty hard and hit the curb with the tire now when i go over 30 i hear a grinding noise on the side i hit "
I'm gonna say wheel bearing
avio
Apr 16, 2010 12:51 AM
schpiel
Sep 17, 2007 07:28 PM
N~FaMouSKhMerBoi
Jun 1, 2004 10:18 PM
