1992 1995 civic hatch differences
were there any differences on the eg hatchback from 92 93 94 95 as to exterior wise (bumpers, fenders, doors etc..) and interior wise too??
-'92 - 93 models have the inserts in the bumper for foglights black, '94 - '95 are painted.
-As stated the '92 - '93 Dash has no passenger's side airbag
-'92 - '93 use a different glove compartment than '94 - '95
-'92 - '93 DXs have a firewall mounted MAP sensor, '94 - '95 and all other hatchback models have a throttlebody mounted MAP sensor (the engine harness differs between these years, '92 - '93 have a seperate MAP sensor harness coming from under the battery tray, its integrated into the engine harness in '94 - '95 models
-'92 models are prewired for vtec to the shock tower plugs
-'95 models use a different fuel filter than all other years
-'92 - '93 models use R12 A/C, '94 - '95 models use R134a
-'92 - '93 models have a smooth climate control bezel, '94 - '95 models are textured and a slightly darker shade of grey.
-'92 - '93 IAT sensor plugs are white, '94 - '95 are grey.
Some of the differences I listed aren't cosmetic, but I figured i'd list them anyway.
orange/white - vtec solenoid
orange/blue - vtec pressure switch
The blue wire you speak of, is it in the driver's side rear corner of the engine bay? If so its the tach test wire, its there for a tech to plug in an external tach.
Thats strictly trim level related, it has nothing to do with year.
ohhh okay, so even if its a 92 si, it should have painted handles?
my hatch is a 93 and I wonder if I have the wiring for VTEC, so correct me if im wrong, are the 92 hatches the ONLY hatches with VTEC prewired into the shock tower harness??
Correct (also personally know someone with a '92 Si and can confirm that it originally came with painted door handles and mirrors)
Only '92 civics (all trim levels, hatchback and sedan, remember there are no '92 coupes.) and all Si and VX hatchbacks.
and someone told me theres a rear bumper difference can anyone confirm??
also pictures would be very helpful
Another thing I'd like to add is that none of the hatchbacks came with a chin spoiler except for the VX trim. The VX also came with some rear air diffuser that is mounted by the back bumper cover.
Also, Si hatchbacks have power moonroofs and mirrors.
Can anyone confirm if the CX and DX came with tachs? I forgot this mundane detail but do remember the VX and Si came with tachs.
I always thought the mirrors were black for the 92 hatchbacks, regardless of trim level. I knew of a few that had 92 Si hatchbacks and they all had black mirrors.
He's saying the 92-93 hatchbacks have BLACK inserts. 94-95 have color matched inserts.
Correct
Off the top of my head. Some have already been mentioned.
Note that my experience is limited to Canadian vehicles (ie., CDM).
- Exterior -
Rear Wiper: 92-95 DX, Si, 95 CX (CDM)
Rear Window Glass Finger-lift: 94-95 CX, VX, DX, Si
Door Trim: 92-95 DX, Si
Driver's Side Door Mirror ONLY: 92-95 CX, VX
Driver & Passenger Side Door Mirrors: 92-95 DX, Si
Power Door Mirrors: 92-95 Si
Body-coloured Door Mirrors: 93-95 Si [Thanks White95SiHB]
Body-coloured Door Handles: 92-95 Si
Power Moonroof: 92-95 Si
Front Lip: 92-95 VX [Thanks 94EG8]
Rear Diffuser: 92-95 VX
Body-coloured Front Air Dams: 94-95 CX, VX, DX, Si
Pre-wired for Fog Lights: 94-95 CX, VX, DX, Si
Wheels:
-13" Steel: 92-95 CX, DX
-13" Lightweight Aluminum Alloy: 92-95 VX
-14" Steel: 92-95 Si
- Interior -
Trunk Light: 92-95 Si
Trunk Mat with Finished Trim Edge: 92-95 DX, Si
Trunk Lid ("Cargo Cover"): 92-95 Si (& DX??)
Rear Speakers: 94-95 Si
Door "Map" Pockets: 92-95 Si
Holyshit Handles, 1 ONLY in Front, "solid handle": 92-95 CX, VX [Thanks all_conference]
Holyshit Handles, 3 Front & Rear, "solid handle" : 92-95 DX
Holyshit Handles, 2 Rear, "solid handle", 1 Passenger, "flexible handle": 92-95 Si
Vanity Mirror, Driver & Passenger: 93(?)-95 Si
Vanity Mirror, Passenger ONLY: 92 Si, 92-95 DX(?)
Large-style Dome Light: 92-95 Si
Upgraded Seat Fabric w/ matching Door Panel Fabric: 92-95 Si
Vinyl Seat Fabric: 92 CX, VX?
"Map" Pocket Behind Front Passenger Seat: 92-95 DX, Si
Foot Rest: 92-95 Si (Any others??)
Tilt Steering: 92-95 DX, Si
Clock: 92-95 Si
Intermittent Wipers: 92-95 CX (CDM Only), DX, Si
Combined Wiper/Washer (CDM Only): 92-95 CX, VX, DX, Si
Tachometer: 92-95 VX, Si
"Shift" Light: 92-95 CX (USDM 49-State Only), VX
Cruise Control: 92-95 Si
Steering Wheel w/ Cruise Control but No Airbag: 92 Si (CDM)
'More' Sound Insulation: 92-95 DX, Si
- Exterior -
Wheels:
- Interior -
Clock: 92-95 Si
Last edited by deschlong; Dec 14, 2011 at 09:12 AM. Reason: Added a few more items.
Every '92 Si hatch I know came with painted mirrors from the factory, perhaps the ones you saw had replacement mirrors? I have seen a '92 EX sedan that came with unpainted mirrors, actually it only had the driver's side mirror, other side had a block off plate. Had the factory painted door handles and licence plate tub too.
Here in the States the 92 Si hatchbacks and 92 EX sedans (both top of the line trim levels) have black mirrors.
Not sure if this applied to the '93 models, but the lower trim level 92 Civics also didn't come with a passenger side mirror (they were optional). I think they were standard on 94-95 models across the board, but I'm not 100% sure since I no longer have the 94 and 95 brochures.
I was beginning to suspect that maybe the Canadian 92 Si models had matching mirrors, and seeing how both of you are from Canada my suspicions have been confirmed.
I've seen a fair number of '94 - '95 CXs with the passenger's side mirror, again i'm not sure what the story is.
Front lip believe it or not only came stock on VX hatches, and DX special edition coupes, also came stock on the Si coupe IIRC, but oddly did not come on the Si hatch.
Does anyone have a sales brochure for any '92 - '95 civic hatchback (especially a Canadian one because quite honestly i'd just really like to see the spec sheet in the back, actually i'd like to see a canadian sedan one as well) that they would be willing to scan and post pics on photobucket?
red 1994 VX
Engine
-d15z1
-oil cooler
-aluminum flywheel
-smaller diameter throttle body
Exterior
-front lip
-rear diffuser
-13" alloy rims
-no side moldings
-driver/passenger side mirrors
Interior
-shift light
-no "Map" Pocket Behind Front Passenger Seat
-no ceiling handles for back passengers
-A/C
Engine
-d15z1
-oil cooler
-aluminum flywheel
Exterior
-front lip
-rear diffuser
-13" alloy rims
-no side moldings
Interior
-shift light
-A/C
'92 only CXs (possibly VXs as well) came with a vinyl interior, all other years were cloth fabric.
I'm impressed here, most people are unaware of those last two items.
My next question: On what CDM models were airbags either: A. Not available; B. Optional; C. Standard; or, D. Installed for both passenger and driver? This is beyond my scope of knowledge for my puny brain. Maybe you can chime in.
CXs I believe it was unavailable (I have yet to see even one that had even a driver's side airbag.) They may have been available on DXs (again I don't think i've ever seen one) They were available on a '93 Canadian LX sedan (seen it with my own eyes) And I believe EX-Vs had standard driver's side airbags for all years (not sure about passenger's side) I think all coupes had a standard driver's side airbag, and I think '94 - '95 models all had dual airbags (this includes the special editions) The oddball LX special edition sedans do not have airbags (I have actual documentation on this one in the form of the suplementary owners manual that came with the car) so far as I can figure out that its my guess that we got a few extra things thrown in to replace the lack of airbags (Special edition sedans are the same as US DX/Canadian LX sedan with the follow extra featues: clock, armrest, dual mirrors, door pockets, special stereo, vanity mirror, and possibly A/C. DX special edition coupes are a similar story, except they have dual body colored power mirrors [obscure fact: Teal DX special edition coupes have a black interior and they have an armrest]
