High Side Wire to/from O2 sensor
Old Mar 3, 2009 | 09:53 AM
cpjp's Avatar
Default High Side Wire to/from O2 sensor
Hello:
I'm installing an electrolizer combustion enhancement device (Hydrogen Hydroxide gets added to the combustion chamber). In order to bypass or fool the O2 sensor into thinking nothing's happening I need to interrupt the signal or high side wire with an electronic device. My O2 sensor has two black wires, a green one and a white one. Can anybody tell me which one is the high side or signal wire? It's a 1990 Accord LX.
Thanks in advance,
cpjp
Old Mar 3, 2009 | 10:10 AM
GhostAccord's Avatar
Default Re: High Side Wire to/from O2 sensor
The signal wire is the WHT wire off the O2 sensor, the WHT/RED wire from the O@ connector to the ECU and it's Pin D14 on the ECU.
Water for gas eh! Good luck with that!.....
Old Mar 3, 2009 | 10:18 AM
cpjp's Avatar
Thank you. Would you know if my car has a MAP sensor?
Old Mar 3, 2009 | 10:25 AM
Yes it does, IIRC there are a bunch of vacuum lines that connect from the intake manifold to a vacuum control box mounted on the passenger side of the fire wall. The vacuum control box contains the MAP sensor. If you have a newer motor than your car it may be mounted directly on top of the throttle body.
RobbieG35
Jun 21, 2006 07:29 AM
Dancing is Forbidden
Nov 18, 2003 08:51 PM
monicle
Aug 23, 2003 07:30 AM
FusionITR
Feb 28, 2002 11:50 PM
