Valve job wearing piston rings?!?!?...need help
Old Mar 3, 2009 | 08:43 AM
HaZed1's Avatar
Default Valve job wearing piston rings?!?!?...need help
About a month ago, i had broken a valve and needed to pull my head to replace it. its a 2001 PY ITR with 84k miles. I figured instead of just replacing the valve and seal, I sent the head to a machine shop locally and they did a complete valve job on it. When I put the head back in, I noticed that i'm burning alot of oil (blueish smoke) Im getting a strong exhaust/fuel stench in the car while driving and at lights sometimes i will see a puff of smoke come pass me when i stop. Im really stuck in a dilemma as too what would be causing this. Ive talked to a bunch of ppl and i get all kinds of different answers. I ran a compression test and it came back fine. Ive put about 400 miles on the car since the valve job and ive burned through about 3/4 of a quart of oil. I finally gave in and called the machine shop. The guy I talked to said that since they replaced all the seals and such, it created such a good vaccum that it wore out the rings on the pistons with 84k miles on them. It doesnt sound right to me for some reason and wanted some input on Honda-Tech and fellow ITR owners.
Old Mar 3, 2009 | 12:17 PM
RockinaRHard's Avatar
Default Re: Valve job wearing piston rings?!?!?...need help
wearing out the rings because of more/increased vacuum... Unlikely. But it could be just burning more oil because the ITRs do that...
Rings, #1 cause of oil burning.
Old Mar 3, 2009 | 12:21 PM
kyden's Avatar
were your cylinder walls scored? i find it hard to believe a broken valve didn't take out something with it.
Old Mar 3, 2009 | 12:23 PM
Not hard to believe, valves can break and not cause a single bit of harm.
if lucky and the part goes right out the exhaust...
Old Mar 3, 2009 | 04:44 PM
94eg!'s Avatar
#1 Super Guy
Loved
...It would then be found in the catalytic converter.
Old Mar 3, 2009 | 05:00 PM
HaZed1's Avatar
^i have no cat...just a hi-flo test pipe...
Cylinder walls were UN-scarred! they looked flawless...still has the cross-hatching on them!
Is it possible that breaking/burning the valve would have also caused the rings to lose tension? I jsut dont know why my compression test would come back with all the same numbers across the board! and i know ITRs burn oil but 1 qt in 400-600 miles? thats quite a bit and still doesnt explain why i have blueish smoke coming out the exhaust. I thought it might have been bc i had oil in my exhaust/header from the burnt valve but that wouldve burned off by now with 500 miles afterwards right?
Old Mar 3, 2009 | 05:56 PM
slo blue's Avatar
when you put the head back on did you run the pcv right? i had a guy install a broken pcv and had a bad oil problem like you stated.
Old Mar 3, 2009 | 08:07 PM
HaZed1's Avatar
ill have to check it out! thanks
Old Mar 4, 2009 | 12:59 PM
HaZed1's Avatar
replaced the pcv valve today and it didnt seem to help any....still smoking. I even threw in my stock OBDII ecu hoping that would help too, but nothing!
Old Mar 4, 2009 | 05:09 PM
slo blue's Avatar
Did they replace the valve seals when they did the valve job?
Old Mar 4, 2009 | 07:33 PM
slofu's Avatar
Even if they did, valve seals are easy enough to ruin with improper install.
Old Mar 4, 2009 | 08:43 PM
wannabar's Avatar
This sounds like there is a problem with the work they did on your head. My guess would be leaking valve seals. (#2 cause for burning oil)
Old Mar 4, 2009 | 08:47 PM
highroller54's Avatar
do a leakdown test.
Old Mar 4, 2009 | 09:44 PM
HaZed1's Avatar
they did replace the valve seals when they did the valve job...im leaning towards something with the head as well! the machince shop is a pretty reputable local shop tho! ive never heard any complaints about them.
Im waiting for my mechanic to get back from vaca to do a leakdown test (i dont have one)
netplaceus
11
Sep 26, 2012 09:06 AM
Panda Eg6
May 29, 2009 07:16 AM
piotrush
Jan 31, 2006 07:38 AM
piotrush
Dec 10, 2005 08:44 PM
1.8T_EG
Oct 21, 2002 12:50 PM
