92 civic lx rear brake disk conversion.
Old Mar 3, 2009 | 07:48 AM
TravisCadello's Avatar
Default 92 civic lx rear brake disk conversion.
I have a 92 civic lx, i have put a z6 Si motor in and si tranny, I'm gunna put a sun roof in it soon, and the only thing thats left for a complete Si Conversion Is my Rear brakes. i seen a si at the junk yard with the rear disk. just curious how hard is it to transform drum to disk? and is it worth it cause people tell me drums are better. and if it is easy how do i do it is it bolt on??
Old Mar 3, 2009 | 07:54 AM
Default Re: 92 civic lx rear brake disk conversion.
anyone?
Old Mar 3, 2009 | 08:04 AM
BlueIntegraBoy's Avatar
It is a direct bolt off and bolt on affair. Make sure you grab the ebrake cables.
Old Mar 3, 2009 | 08:18 AM
commotion's Avatar
yah i just finished mine i used 01 teg brakes though just bolts right up you will need the Trailing arm and brakelines. and ebrake cable
Old Mar 3, 2009 | 08:26 AM
so take the brake lines and e-brake lines? what about the master cyl do i need a better one?
Old Mar 3, 2009 | 08:29 AM
oh yea, and how is rear disk gunna help me? will they stop faster?
Old Mar 3, 2009 | 09:11 AM
everythingwentblack's Avatar
its like comparing a hooker girlfriend to like...Megan fox. Megan fox is hotter, more efficient and all around a better choice.
As for the rear disc brakes, their a million times better then drums and can be done with a fair amount of ease since it is a direct bolt on. When I did mine I didnt know anything about **** but i still figured it out and Ill be the first to admit im half retarded.
You dont necessarily have to swap out master cylinders, brake boosters, or the 4040 prop valve, but i would suggest it. I still have my stock ex MC/BB and prop valve as well since I havent gotten around to spending 30 bucks at sears for a set of master torques they wont let me return that Ill use once.
mynameizstitch
10
Dec 13, 2009 03:06 PM
Del_Sol_s
Feb 3, 2005 01:30 PM
untitled
Sep 5, 2003 02:35 PM
Forrest Gump 9
Jun 21, 2003 03:22 PM
