88 civic b16 problems
Old Mar 3, 2009 | 02:20 AM
mario626's Avatar
Default 88 civic b16 problems
ok so i swaped in a b16a it ran good for like the first couple days ten it would be driving and it boggs out and feels like it looses all power then goes again but after doin this for a while it will turn off then wot turn no more and when i check it has no spark what can be the problem ?
Old Mar 3, 2009 | 04:09 AM
88hybrid's Avatar
Default Re: 88 civic b16 problems
check the distributor. possible swap with a known good one and try that. had the same problem last week and that was the cue. hope this helps!
Old Mar 3, 2009 | 04:44 AM
90civichbsi's Avatar
what he said ^. make sure the rotor didnt come loose or something if you replaced it.
Old Mar 3, 2009 | 06:59 AM
LudeEFv2.4's Avatar
My old title sucked.
Exactly^^^ those things have a tendancy to go bad if the engine has been sitting around for a while. Is your tach jumping around as well?
Old Mar 3, 2009 | 09:37 AM
EL Vap133's Avatar
Beat me to it, the rotor screw can be very tricky sometimes.
P.S. Are you throwing any codes?
Old Mar 3, 2009 | 09:41 AM
ALLxMOTOR EG's Avatar
Vietnamese!
All of the above.
Old Mar 3, 2009 | 10:38 AM
Targa250R's Avatar
be professional
Likely a bad igniter.
Old Mar 4, 2009 | 02:19 AM
mario626's Avatar
yeah its shows code 14 at first then after drivin it around and it starts boggin out it throws 22 and 17
Old Mar 4, 2009 | 04:24 AM
Targa250R's Avatar
be professional
Sounds more like a wiring issue. Who did your MPFI conversion? What ECU are you using?
Old Mar 4, 2009 | 10:54 AM
mario626's Avatar
we did nad im usin a pw0
Crashmaster91
May 29, 2014 03:03 PM
JDMEMone
19
May 3, 2011 07:22 AM
tatted91rex
Feb 25, 2006 09:37 AM
nitrousjunkieCRX
Aug 26, 2004 05:49 AM
civicsk8er
Apr 20, 2004 02:27 PM
