please help , car wont start
here's the problem , when i turn the key the first time cigarette lighter , radio etc , power comes on . on 2nd turn the fuel pump comes on , loud and clear you can hear it . now when i actually go to start the car the cluster lights up , but nothing happens , if it helps , ( if it helps , when i start the car i hear the main relay click . ) . some one any one every one , please help a family member out . thanx
make sure all the grounds are hooked up on the motor but More than likely there is one single wire that runs to teh starter that likes to pop off make sure that is plugged into the starter and the motor and tranny are grounded
Theres a start
Theres a start
Are you saying that the starter doesn't crank the engine when the key is turned to ON(III)? If so, is the battery fully charged? Does the starter turn the engine if you wire it directly to the battery? Can you push start the car (MT only)? Are any fuses blown?
no crank wut so ever battery is good starter does not do nothing with a direct connect , fuses are good and i didnt try to push start it thanx to the stupid *** snow in ny
how about the sinlge 12 gauge wire that runs to the starter is that plugged in ??? that is the wire from the igntion that signals teh starter to kick over
Sounds like the starter is dead or the engine is locked up. Do you hear the starter trying to turn the engine but can't? Are you able to turn the engine by putting a wrench on the crankshaft pulley bolt (turn counterclockwise only).
seriously smack the starter with a hammer it may be locked sometimes starters will still work after a few smacks lol it would work for a lil while but woudl recomend replacing if this works
all of my ideas are only if the starter is not turnig the motor over it is that opens a book of different things it could be lol so hopefully its just a dumb starter issue
My car has the same problem !! I took the starter to autozone they said it was good, i checked all the grounds, all the fuses, the battery is good, i even tried another starter, And no luck !!
Happened to a friends car : ring gear on the flywheel ( the part with the teeth ) seperated from the flywheel
Keep in mind all my ideas are if the motor itself is no turning over
Take off your transmission ground and wire brush it real good. also take the chassis down to bare metal where it grounds, sounds crazy but thats what made mine start when I had this EXACT same problem. it was just a fouled ground. you can read my thread by clicking my S/N and searching my posts. "Ron@ht" helped me signifigantly.
