Adjustable Fuel Presure Regulator.
Just Curious what does an adjustable FPR do. and is it worth buying.
and also a hondata what is the diffrence? it only seems like it revs higher.
Whether or not these parts are "worth it" depends on your goals. Also, Hondata offers a range of features that you may or may not use...depending on your setup. We'd have to know more in order to give you a better answer
My opinion if the car is mildy modded and all motor FPR is a waste of money if its boosted than maybe but if ur mostly stock i wouldnt bother i had a stock ecu w/ after market intake manifold throttle body cold air , header full exhaust amd still cut anywhere from %13-%24 fuel thru-out the RPM's
Unless you're making some serious power, the FPR is a waste of money as is an aftermarket fuel rail (some people swear by the combo). I'm shooting for 450whp and i'm still rockin the stock FPR and rail. Also, i'm running Crome...not Hondata
I %100 AGREE !!!!!
We would get along LOL
sivikvtec
Aug 25, 2006 10:17 AM
justmotor13
15
Nov 20, 2002 03:01 PM
