type R motor issues!!!!!!
I got a 2000 civic Si with a type R motor swap on it that was doing me fine for about 2 years. I park the car ever winter, and this winter, it was parked for about two months, and then when I tried to start it, it seemed like the timing belt was stuck? The car will roll, but something in the motor is keeping the timing belt from turning.
I think the crank is trying to turn, but there is something holding it back from cranking. (yes, I did hook up the battery charger right).
I took it on the road and tried to jump start it, but every time I let go of the clutch, the wheels locked (no rotation). I did it a couple times, and I gave up. If the car is in neutral, it will roll, but wont start.
I dont think its the transmission, but I have no idea what could have happened. I dont know if something might have froze during the winter, but I would have thought that jump starting it would have gotten it to unlock (and its like 60degrees outside).
Someone PLEASE HELP!!!!!
take the plugs out and turn it over... see if it spins and shoots stuff out... if it still dont spin, idk, if it DOES spin easily, put the plugs back in and fire it up.
could be valve guides/seals leaking... sat forever, oil puddled in cyl, and boom, hydrolocked
THe car was had never over heated, and has oil in it. I checked to se if there was any animals in there and nothing. I will try the spark plug idea, but idk how to find out which one of the timing pulleys is seized (if it is one of the pulleys).
When my friend try's to turn the key, I can see the timing belt try to spin, but nothing turns and it looks like the crank is just jerking the belt a little.
I have no idea what could be the problem??????!!!!
Did you take the plugs out? Might not be the problem but couldn't hurt to try it.
I hydro locked a truck once and your symptoms sound identical to the trucks after i drove through a huge mudhole.
hmm, thats an interesting problem you have there. other then whats already been said i don't really know what to suggest. once you do get it figured out though i'll be curious to hear what the issue was.
hmmmmmmmm i'd start by taking a wrench to the crank shaft pulley and trying to rotate the motor by hand. how cold did it get where the car was parked? is the coolant level topped off? i'm hoping this isn't your case, but if you had more water than antifreeze in your engine the water could've frozen, cracked something and BOOM hydrolock... either way it sounds like there's liqued in one of the cylinders... good luck!
zx92027xz
Sep 10, 2015 11:31 AM
Lao17
12
Aug 2, 2011 01:49 PM
f22b1kid
Oct 31, 2008 01:48 PM
1990CIVIC4WD
Sep 26, 2003 07:17 AM
