Upgrade advice needed
like buddy said i need brakes suspension drivetrian and then motor upgrades
heres my dilemma i dont know what to buy and whats a good price for it.
can i get any help on what brand, a good price range for the parts i'd need to upgrade each aspect
budget: around 5k im getting sign bonus with guard if i join(high probability of that)
I will go suspension and brakes first. Cant tell you what to get because everything buys to their liking, but i have DA all around brakes and koni/gc coilovers at 500f/550r
x2 upgrade brakes and suspension first,no point in being able to go fast if your car handles like **** and can't stop.just my 2 cents
ok umm woul di be better off with a whole brake kit or buy indivdual parts for brakes
and what about
http://www.autopartswarehouse.com/de...517050730.html
also whats the difference between coil over and coil springs
and what about
From what i know, coil overs you can adjust anytime of day as you please. and a coil spring you can get a stock height or lower, but are not adjustable. The Skunk2 kit is also a coil over kit.
Start with Rear Disc Conversion. While you doing that you can change your suspension at the same time.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rear-disk-brake-conversion-w-pics-1916212/
Dont worry about removing the tank. you dont have to remove it at all.
theres several options. 11.1" rotors or DA Brakes as well. But you going to need a 4040 prop valve from a DA and 15/16 mc/booster non abs. Your stock wont be able to push enough fluid to the calipers.
Try reading about your car, what others have already done (tons and tons of info on here), and taking a step back to really consider what it is you're trying to accomplish with your car and what it's all worth (now and after a few years).
im trying to make this car not only a good driving car but a semi-show, seeing as it was once a show car (im getting pics soon) i would like to keep it in the game by upgrading the parts that arent so spiffy because everything but the paint job pretty much sucks i want to make a better looking car and a better performaning car
Hellzcivic
Honda Civic (2006 - 2015)
Jan 16, 2007 05:22 PM
BiMM3R85
Mar 31, 2006 05:44 AM
