HELP on my ls swap civic
Old Mar 2, 2009 | 02:02 PM
joshie123's Avatar
Default HELP on my ls swap civic
so i did the swap but the bad thing is im new to the honda world so this is the problem i did a ls swap si trans but i got the stock d15b7 ecu can it work for the b18b or do i need to git a new one
Old Mar 2, 2009 | 02:07 PM
94EG8's Avatar
Seagull Management
Default Re: HELP on my ls swap civic
you can chip the P06 you have with P75 maps, or use an OBD1 P74 or P75 ECU.
Old Mar 2, 2009 | 06:03 PM
joshie123's Avatar
so a p 74 or p 75 will plug right in no hassel tryin to git out moving so i can start workin buggs out b4 spring ya know
Old Mar 3, 2009 | 06:14 AM
94EG8's Avatar
Seagull Management
Yes, just make sure if you use a P75 ECU that you get the OBD1 version, they were also available in OBD2. P74s are OBD1 only so not much room for error there.
TNHOTROD
Engine Management and Tuning
Feb 10, 2012 07:13 PM
heeltoehonda
Nov 19, 2009 11:41 AM
Ahknodd
Jul 21, 2009 08:06 AM
99civicSiT
Mar 18, 2008 11:55 AM
drewlee
Jan 6, 2003 01:53 PM
