Drivetrain problems.. need help ASAP
Old Aug 11, 2002 | 12:10 PM
[626]95-GSR's Avatar
Default Drivetrain problems.. need help ASAP
I have a d16a6 with an HF tranny (dont ask why)... Recently ive been having major problems putting my car into gear.. I push the clutch ALL the way down, try to put it in First.. and it goes in with A LOT of resistance. I have to FORCE it into gear.. and when i do finally get it into gear... the car shudders, as if the clutch is engaged. Second gear, I have to force it in also. Third gear goes is with a HUGE grind.. putting the car in Reverse come with a huge, nasty grind as well. The clutch grabs HARD, its a 6 puck dual diagphram action clutch. I tried to adjust the clutch cable a little, but the problem always comes back.. ive actually adjusted it all the way, now theres no more cable left.. what is the problem?!
_______
Old Aug 11, 2002 | 12:14 PM
Chiovnidca's Avatar
Default Re: Drivetrain problems.. need help ASAP ([626]Rj-SiHatchy)
Is your clutch fork bent? Is your pedal bracket broken?
Old Aug 12, 2002 | 07:25 PM
BreakStuff's Avatar
New User
Your car is also equipped with a "shifter rod" that connects from the trans to the shifter, sometimes the end that connects to the shifter gets rusted out and bends from everyday shifting, shifter bushings also get worn out and make it a bitch to shift.. find the bolt that attaches to the shifter rod and loosen it up a tad and see if that makes a difference..
unknownally
Transmission & Drivetrain
11
Jul 24, 2010 03:20 AM
95f22a1
15
Apr 30, 2007 11:40 AM
Lo-Buck EF
Apr 28, 2003 06:56 PM
[626]95-GSR
Aug 11, 2002 08:51 AM
[626]95-GSR
Aug 11, 2002 12:24 AM
