Bouncy lights when the card is cold
Old Mar 2, 2009 | 10:52 AM
MWLW20's Avatar
Default Bouncy lights when the card is cold
Sorry for such a noob question but my gf's hatch headlights, and rear lights surge when the car is cold but after it is warm the problem goes away. Also, when the turn signals are used the turn indicator light on the cluster blinks twice as fast as normal and also stops when the car is warm. Any help would be great. thanks
Old Mar 2, 2009 | 10:57 AM
Former User's Avatar
Default Re: Bouncy lights when the card is cold
Check whether the alternator belt is loose or glazed.
One of the turn signal bulbs may not be the correct type or is burned out.
Old Mar 2, 2009 | 11:17 AM
MWLW20's Avatar
Could it be the alternator belt? Could that affect the lights cold but not when the engine is warm because the belt is slipping when it cold? Is that what you are saying?
Old Mar 2, 2009 | 11:18 AM
Yes, it's a possibility.
If the belt is fine, have the alternator tested at AutoZone (free service). Also clean and tighten the battery connectors and ground wire in the engine bay.
Old Mar 2, 2009 | 11:19 AM
instructor74's Avatar
+2 I would also make sure that the alt is charging correctly and would also check and clean all your grounds.
Rvkeg6
11
Feb 5, 2012 01:37 PM
Ojum pmantwenty3
Jul 14, 2009 10:21 PM
Backk InTheDA
Dec 20, 2005 08:09 PM
PaisanITR
May 18, 2005 06:23 AM
gatesrex91
Jan 21, 2004 09:11 PM
