No start after mpfi swap??
ok so my buddy did a mpfi swap on his car, and it didn't run cuz of some wiring gremlins. i fixed the gremlins on it, and now i'm trying to get the car running, but it guess i missed some. timing is good, gets fuel (just a header and down pipe so i can smell it when trying to start). set up is an 88 std hatch 4spd manual w a d15b1 w a b7 cam, z6 intake mani w obd0 injectors, obd0 ls throttle body, pm6 ecu, resistor box is installed, new plugs, tried two different dizzy's both have no spark. the first one i tried the coil was warm after trying to start it for a while. battery was relocated to trunk, the thermostat ground is hooked up, so is the valve cover ground... i'm going to try swapping the cap. gas is almost on the red so maybe i should ad some gas? idk it just cranks and cranks, doesn't even try to catch... kind of stumped here! lol only code it throws is a rapid 4 (this show's up after trying to start it a few times on both dizzy's) i physicaly looked at the wiring and re did it twice to make sure it was correct... spark plug wires are all in the correct order too... i'm stumped!!
please help, i want my car running!! driving a mini van sucks. lol
thanks to all that can help!
-DCRB
-DCRB
yeeaaaaaaaaaaaaaah i NEED it runnin man my brakes are down to rivets and when i stop hard i smell metal on metal...
DUH i didn't even think to check the two white wires, i'll check in a bit (gotta do laundry first) and post back
same happen to me and i miss a ground wire..that was my problem it crank but no spark or anything and when i re check the wiring i miss to bolt up a ground wire..
so i reset the ecu, no longer throwing the code 4 but is throwing a code 5 and 14. from searching it looks like code 5 is a mechanical problem w the map (vacuum leak i'm guessing? one of the vacuum bungs is just plugged off w tape. still smokes like a train. lol
ryanevansoh
11
Jun 1, 2011 06:20 PM
xxstuntin4life
Oct 9, 2009 06:49 AM
